04 5.4 liter FlexFuel Conversion? is it possible?
Old Apr 26, 2007 | 10:48 PM
rangermach1's Avatar
I have an 04 scab f150 with the 5.4liter 3valve motor. the 05 and up models are offered in a flex fuel version, but the 04 was not. I called my ford dealer, and he said it could be done, but at high price. I find it hard to believe that there is that much different. I say this because Ford offers this flexfuel option at no additional charge. has anyone done this already, or have any idea how? It would help alot were I live, because E85 is only $2.12 a gallon or less compared to $2.89 for 87 octane gas. this savings could pay for itself in a year.
Old Apr 26, 2007 | 11:23 PM
()smoke()'s Avatar
very possible to convert, whether it will pay for itself in a year depends on how much it costs, how much you drive and whether the current prices you quote remain in effect for a year...but my initial guess is no way
Old Apr 27, 2007 | 12:10 AM
chester8420's Avatar
It is possible to convert. Whether or not it is harmful is a debate that could only be settled by the designers of the vehicle....
1. Are ALL the fuel delivery components capable of withstanding E-85?
2. Are the engine components capable of withstanding the corrosive nature of E-85 and it's potentially corrosive combustion byproducts?
3. Will the fuel delivery components keep up with the extra fuel requirements?
4. Can you convince the computer to deliver the right ammount of fuel?
5. Can you convince the computer to deliver the correct ammount of spark advance?
6. Can the catalytic converters handle it?
I guess the most important question is... Can you afford to fix the truck if you break it?
Old Apr 27, 2007 | 05:05 PM
Quintin's Avatar
I suppose it could, but why would you want to? Fuel mileage with E85 is significantly less than what you get with gasoline, so you're using more E85 to go the same distance you would using gasoline. Kinda hits the point of diminishing return - there ain't no such thing as a free lunch.
Old Apr 27, 2007 | 05:14 PM
korbela's Avatar
Exclamation
Yes all of the gasket that are used now with companies offering E85 are E85 ready
Once again as answered above if the manufacturer offers it the engine ready for it even if it is not in your car
Yes. the only thing that changes is the time that the injectors are open 1-4ms more
Thats the ticket you may have to change you computer or purchase a E85 converter kit so that your injectors stay open longer.
Spark does not change
E85 runs cooler than gas so yes the cats can handle it, it burns cleaner than gas.
Shouldnt break at all..
****Important note please not that if E85 is $1.00 and gas is $2.00 that you will use approx 1.25-1.30 gallons of E85 to equal gas just because its less expensive doesnt mean it's cheaper. My cutoff out here is when gas is over $2.75/gallon and E85 is 1.99-2.09 then its worth it for me.****
Hope that helps.
Miko
Old Apr 27, 2007 | 07:22 PM
MGDfan's Avatar
I suggest you use the search function to pull up all relevant E85 posts by a member named "Tschaid". He has actually already done this.
Old Apr 27, 2007 | 11:22 PM
Netduke's Avatar
I will be converting my 04 to run E85 once gasoline hits $4.50 a gallon... The higher octane that E85 has would be helpful too.
Its mostly just a new tune, fuel pump, fuel lines, and injectors i think... hopefully...
Old Apr 27, 2007 | 11:36 PM
turtle313's Avatar
As MGD said, SEARCH! This topic has been discussed and argued about extensively.
