Persistent misfire in #8
Old Apr 24, 2007 | 11:02 PM
90StangLX's Avatar
I've replaced plugs, wires, and crank position sensor, and also swapped my coils from side to side and the miss stays in cyl #8. Any other ideas? All I can think of is perhaps an injector issue.
Truck is a '97 F150 4x4, 4.6L automatic with 16x,000 miles on it.
Old Apr 25, 2007 | 06:58 AM
torkum's Avatar
Try swapping the injector, if thats not it could be internal. Do you feel a miss? If you don't feel it then your PCM could be the problem.
Old Apr 25, 2007 | 02:13 PM
90StangLX's Avatar
UPDATE:
After posting this thread, the misfire has moved to cylinder #3. I replaced the coil pack with one that is known to be good, yet the misfire persists in its new home. Later today after the engine cools I am going to pull the plug and take a look, and if it looks good add a healthy dosage of dielectric compound and put it all back together. Any other ideas? What could cause the seemingly random misfires?
Old Apr 25, 2007 | 03:41 PM
jbrew's Avatar
I wouldn't mess around with it - plugs, wires, two fresh coil packs or you'll be pulling your hair out - get em from Global auto and pay half price..
You need to get your motors integrity back ...
Old Apr 25, 2007 | 06:41 PM
90StangLX's Avatar
All of that stuff is essentially new, and it's all motorcraft parts, yet the misfire won't go away. I'm already beyond pulling my hair out...
Old Apr 25, 2007 | 07:38 PM
jbrew's Avatar
I know how that is. Looks like all you have left to replace is one coil correct?
What cylinders is the known good coil handling?
How did you determine #8 was misfiring?
How old are both coils?
Did you have any water at all on the motor or did you wash it recently? Are all wires sealed w/wire sealer?
Do you see any spark/arce in the dark while your motor is running.
If your running a stock coil by chance that's over 6 years old - it has served you well and needs to be replaced..
How old are the wires and plug exactly ?
