troubleshooting p1451 code
Old Apr 17, 2007 | 08:04 AM
vaughn27's Avatar
Ok I need some help.. I want to test the cannister vent solenoid on my truck. I have read through the forums and they say I need to check the ohms, and they should be between 50 and 60 ohms.. My question is how to I do that. I have a tester at home and it does have an ohms setting on it.. Any help would be appreciated.
Old Apr 17, 2007 | 02:17 PM
projectSHO89's Avatar
You will need a multimeter that has the ohms function....
Sears or Radio shack ususally has them for under $20.
Steve
Old Apr 18, 2007 | 08:05 AM
vaughn27's Avatar
Yeah I have the tester.. but once I get the solenoid off the vehicle how do I test it. From what I have read there are coils in it. Do I just put the tester on each side of the coil and check the ohms?
Old Apr 18, 2007 | 11:25 AM
Put one test lead on each pin of the connector and make your reading.
Adust your scale as needed if not an auto-ranging meter to give the highest resolution reading.
Old Apr 19, 2007 | 07:16 AM
vaughn27's Avatar
thanks that seems simple enough
