What Is Wrong?
Old Apr 10, 2007 | 09:54 PM
reddrooster's Avatar
What Is Wrong?
Greetings F-150 Experts!
I have a 2001 Supercrew, 4.6L, 4sp O/D. At the beginning of my drive to work (54 miles) this morning, I noticed a sort of bumpy feeling when accelerating through 30 MPH. Almost a vibration. I pulled over to check the engine and it was running smoothly. I didn't notice it again until the ride home in traffic. Pretty much at low speed and when the transmission was changing gears. I checked the fluid, per the manual instructions. It is fine and didn't smell burnt. I continued my drive and in a few miles, the "Service Engine Soon" light came on.
I plan to take to a shop in the morning but does anyone have an idea what happened or could be causing this? Seems like a transmission issue but would that cause the light to come on?
Thanks,
Steve
Old Apr 10, 2007 | 10:00 PM
torkum's Avatar
We won't know till you get the code, but I'll guess a misfire.
Old Apr 10, 2007 | 10:17 PM
Thank you for the quick response!
To get the code, I can just take it somewhere like Auto Zone, right?
Old Apr 10, 2007 | 10:23 PM
SlammaJamma's Avatar
Correct
Old Apr 11, 2007 | 01:02 AM
Klitch's Avatar
just to clarify for you. normally a serious transmission issue will make the o/d light flash.
Old Apr 11, 2007 | 04:21 AM
jbrew's Avatar
I'm gonna take a guess - PO304
Old Apr 11, 2007 | 10:17 AM
correct, PO304 it is.
I have dropped off at a hopefully, fair, repair shop. I will post the diagnosis. As soon as I know.
Old Apr 11, 2007 | 05:05 PM
jbrew's Avatar
Hahaa , lucky guess .
Good luck
Old Apr 11, 2007 | 10:34 PM
Good luck
Well...it's defined as a bad coil on #4 and they are going to replace that, plugs & caps. Also do a fuel service because with the bad coil, extra fuel was being supplied to the other cylinders and fouling the plugs. They say.
There is a coil for each plug? I guess I'm "old school" thinking there is "a" (single) coil that supplies a distributed voltage to the plugs.
I'm in a rental until tomorrow sometime.
Thanks for the feedback and information!
Steve
Old Apr 12, 2007 | 12:23 AM
jbrew's Avatar
Not true - the injectors continue to pulse normally , no adjustments are made. - raw fuel continued to dump #4 cylinder which fails to ignite therefore collecting in the converter.
After a prolong period of time , the PCM may shut down the injectors (all of them) in an attempt to preserve the catalytic converter, it could ignite - I not sure of the time frame.
Yes, 8 coils within your Coil on Plug (COP) system..
