slow idle return after rev
Old Mar 27, 2007 | 07:37 PM
smig1's Avatar
I have an 02 reg cab 5.4, and when im parked and pump the throttle, the revs jump up respectively quick but return to idle very slowly. It takes around 2-3 seconds whereas my dad's 99 supercab 5.4 returns almost instantaneously.Whats up?
Old Mar 27, 2007 | 07:55 PM
plug's Avatar
check your TPS, this could very well be the problem and also check to make sure that the throttle body doesn't need to be cleaned.
Old Mar 27, 2007 | 07:59 PM
jbrew's Avatar
Thanks , you just helped me figure out why mine has been doing that . I have 3 or 4 different TPS's and I think I slipped a different one on it when I had it apart the last ..
I didn't think about that untill I read this..
Old Mar 27, 2007 | 08:38 PM
smig1's Avatar
Im new to f150's as i just got this one, i had a 5.8 bronco before. can you elaborate?
Old Mar 27, 2007 | 09:04 PM
jbrew's Avatar
Cleaning your TB and IAC - Click on the link -
http://www.fordf150.net/howto/throttlebodyclean.php
Old Mar 27, 2007 | 10:10 PM
angus242's Avatar
TPS = throttle position sensor
THIS IS NOT EXACT but this is what one looks like:
As jbrew said, clean throttle body, IAC valve and don't forget the EGR ports too.
Old Mar 27, 2007 | 10:21 PM
chris1450's Avatar
Chances are it is normal. Ford uses the slow return to idle for emision reasons. If the throttle plate slams shut quickly, one aspect of the emisions is high.. I think hydrocarbons or NOX. Ford has been doing this since about 1981 on most of there vehicles.
