asked ALOT!!
Old Mar 12, 2007 | 11:41 PM
Bobby??'s Avatar
asked ALOT!!
I no this is asked alot but i just want to make sure. would a 2004 5.4 engine fit in a 97 f150 without any major mount mods
Old Mar 12, 2007 | 11:50 PM
Zaairman's Avatar
It'll fit, but the wiring and computer is damn near impossible to do.
Old Mar 13, 2007 | 02:06 PM
Jordan not Mike's Avatar
You need to replace the gauge cluster as well.
Old Mar 13, 2007 | 02:15 PM
s1037s's Avatar
if it is a 3valve, then you will have wiring issues. if it is a two valve, no problem, use your stock coil packs and it will go just fine
Old Mar 13, 2007 | 09:26 PM
Zaairman's Avatar
The "extra super custom impossible wiring" would fix that.
2004+ is a 3 valve.... unless its out of a Heritage.
Old Mar 14, 2007 | 12:09 AM
He's got an NPI motor in his 97.
Putting an entire 2-valve PI motor in would require a lot of rewiring...there are several threads on this. I hav considered it at one point myself, but it was more work than I wanted to invest.
Going to a 3-valve motor...I'd imagine would be even more work
