engine size
Old Feb 20, 2007 | 11:25 PM
Bobby??'s Avatar
engine size
i was wondering if i 4.6 or 5.4 v8 woudl fit in a ranger. woudl it fit at all if there where a few mods or am i just a dumbass for asking
Old Feb 20, 2007 | 11:32 PM
Neal's Avatar
Cool
HI!... Yes either one will bolt in, but you will have to make custom motor mounts. I have a 408 in a RANGER and I used a engine plate to mount it.
Old Feb 21, 2007 | 06:51 AM
adrianspeeder's Avatar
They stuff the 4.6L in the exploder, so I'd guess the ranger would be big enough too.
Adrianspeeder
Old Feb 21, 2007 | 07:30 AM
s1037s's Avatar
must be something in the air...i was dreamin' the same thing
Old Feb 21, 2007 | 09:25 AM
98Lariet4x4's Avatar
Unless you just happen to have of those sitting around, I'd recommend dropping a 302 in it. For about $600, you can get a bolt on adapter kit that includes evrything you need. And you can easily get 350 HP from a 302.
Old Feb 21, 2007 | 07:16 PM
GIJoeCam's Avatar
A 302 or a 4.6 were both available at one time or another in the Explorer of the same generation, so they *should* shoe-horn under there without too much difficulty. 2wd is easy enough, 4x4 is a bit more of a challenge, but not at all impossible.
-Joe
Old Feb 21, 2007 | 11:26 PM
Steve83's Avatar
I'd use an Explorer/Mountaineer 4.6L setup. Once you collect all the parts, it should drop in without fabrication of any kind.
Old Feb 22, 2007 | 06:07 AM
GIJoeCam's Avatar
Don't forget about the transmission... you'll need the trans from the donor vehicle as well. AFAIK, the 5R55E doesn't bolt up behind the V-8s. (A4LD IIRC?)
-Joe
Old Feb 22, 2007 | 01:33 PM
Steve83's Avatar
I'm pretty sure the 5R55E is just an updated 4R70W, which is an updated AODE (which is an updated AOD). Since most AODEs (3-bolt starter) & all 4R70W were made to fit the 4.6L (modular family), I think it'll drop in. A few AODEs (2-bolt starter) & all AODs fit the 5.0L (smallblock family). Bobby didn't say what year his Ranger is, so IDK what trans/engine he has now.
