Loud Engine Whine
Old Feb 19, 2007 | 12:50 PM
TennTriton's Avatar
Loud Engine Whine
My 99 F150 5.4L has started making a very loud, low-pitched whinning sound from the engine. It sounds like it's coming from the passenger side, top of engine, but I'm not 100% sure.
I was certain it was the idler pulley, but after the swap, the sound is still there. So, I removed the belt and started the engine. The sound remained even with the belt off.
Some more specifics for anyone that may have experienced this:
- Engine is quiet at cold start; sound develops only after engine is warm
- Whinning sound occurs when engine is at near idle RPM's; goes away with throttle
- Occurs in park, neutral, or drive
Any advice on what I should check next (short of taking to the dealer) would be most appreciated.
Thanks.
Old Feb 19, 2007 | 01:32 PM
chester8420's Avatar
Thanks.
Check for vacuum leaks. Namely, the pcv elbow where the pcv hose connects to the intake.
Old Feb 19, 2007 | 07:12 PM
Gear Jammer's Avatar
While your looking at that pcv elbow go ahead and replace the pcv valve. When they get nasty they start buzzing. I had no clue about this until about two weeks ago. My truck made an annoying buzzing sound at idle that would wind down after I shut the truck off. I did a search for "buzzing" and came up with bad pcv valve. I had my doubts but I replaced it anyway and I'll be damned if it didn't work.
Old Feb 19, 2007 | 07:42 PM
TennTriton's Avatar
Thanks Chester and GearJammer!
You guys were right on. Replaced the PCV valve and the elbow. Problem solved.
Thanks again.
