part number for oxygen sensor
Old Feb 14, 2007 | 11:39 AM
d4guk2000's Avatar
Post part number for oxygen sensor
does anyone have the part number for a ,bank 1,sensor 1,pre cat ,oxygen sensor for my 2001 harley f150 5.4 non supercharged,kind regards darren frm the uk
Old Feb 14, 2007 | 01:41 PM
JMC's Avatar
JMC
25 Year Member
Go to the Bosch site and fill in the blanks. http://www.boschautoparts.com/Resour...clePartFinder/
JMC
Old Feb 14, 2007 | 01:44 PM
pjb999@yahoo.co's Avatar
Hey Darren,
Apart from asking your local dealer or calling Ford UK, (assuming you're in UK) quoting your vin #, I would think the best thing to do is read the numbers off the sensor itself, since there can be variations in parts on local vehicles owing to local regulations/specifications etc....
Having said that, some will say the specs are quite broad and there are universal o2 sensors available - some will argue you should replace with exactly the same. I suspect the truth is somewhat inbetween as the truck's computer is adaptive....but of course it does expect a certain value from a sensor, so it could be like trying to measure something with a rubber ruler.
Presumably you have good reason to think yours needs replacing, and I guess 20years or so on from when O2 sensors started appearing, the evidence suggests they are indeed a consumable that needs to be replaced periodically. Like any chemical reaction based thing under such extremes, values change over time, and without the ability to calibrate, replacement's our only option.
Old Feb 14, 2007 | 03:29 PM
JMC's Avatar
JMC
25 Year Member
In UK they are called Lambda Sensors. Bosch is the best and that is most likely what came on your truck. I use the universal after cat sensor as it is cheaper then the short wire one.
JMC
Old Feb 14, 2007 | 07:10 PM
d4guk2000's Avatar
bank 1,sensor 1
JMC
thanks jmc.i checked the bosch website and it states that 2 oxygen sensors are required,my dealer told me all i need is the ,pre cat ,bank 1, sensor 1.can i buy one or am i getting wrong info.regards darren
Old Feb 14, 2007 | 07:17 PM
JMC's Avatar
JMC
25 Year Member
I always replace them in pairs but when ££ is tight I change them 1 at a time.
JMC
Old Feb 14, 2007 | 07:21 PM
d4guk2000's Avatar
o2
JMC
cheeerz jmc ,ill replace the 1 for now and see how i go .many thanks for helping me .ive only had the truck for 5 weeks ,so not to clued up about it yet.thank you .darren
Old Feb 14, 2007 | 08:43 PM
d4guk2000's Avatar
o2
Originally Posted by pjb999@yahoo.co
Hey Darren,
h had ob11 done ,and it gave code po171,which is the bank 1,sensor 1.regards darren
Old Feb 15, 2007 | 06:28 PM
d4guk2000's Avatar
replacing both
hi mate ,took your advice ,ive got 2 o2 sensors on order.thanks darren
