Rough idle issue,someone help please!
Old Oct 8, 2009 | 09:58 AM
  #31
witte's Avatar
Think i found the prob ,
When i disconect 1 ignition coil and start the engine , it runs bad but it goes .
When reconecting that coil again and disconect the other one , it gives me backfires and runs completly different .
My opinion is that 1 of the 2 coils are defect .
I ordered one and on wednesday i wil have it .I let you know if its fixed .
thx
Old Oct 8, 2009 | 12:05 PM
  #32
P1409 is an EGR code. Here is how to check that:
http://www.2carpros.com/forum/1999-f...-vt340938.html
Old Oct 8, 2009 | 03:07 PM
  #33
witte's Avatar
Hey glc,
thx , i wil check that .
Thx
Old Oct 15, 2009 | 05:45 PM
  #34
witte's Avatar
Hello Glc ,
I have replaced the ign coil , but no succes lol .
i have folowed your egr diagram but do you have a electric wiring diagram from sutch a ford f150 from 97 .
i have mesured the ohm from the coil and thats ok . but for de pcm , are those wires correct . I have seen that they are talking about a ford cortina ?
Thx
witte
Old Oct 15, 2009 | 06:45 PM
  #35
jbrew's Avatar
A 97 F 150 what ?
Fill your info in top right corner. Post WHAT diagram, we have 3 different motors in our trucks and their not all wired the same.
Old Oct 16, 2009 | 05:26 AM
  #36
witte's Avatar
Hi Jbrew
I filled in the info ,
Ist a Ford F150 from 1997 . 4.6cc V8
I'm looking at the wiring diagram from the egr solenoids because i have always backfires and trouble code P1409 manufacturer specific code .
Thx
Old Oct 16, 2009 | 07:02 AM
  #37
jbrew's Avatar
You check the wires at the sensor. Here, this should help -
http://www.fordscorpio.co.uk/egrmonitor.htm
The EVR is a simple fix, they usually break right at the connector. Check your VREF (Volt Referece) / Then check the sensor operation itself. There's a foam filter under the cap, but remember 1409 points to power.
Why did you replace a coil ?
Old Oct 16, 2009 | 08:53 AM
  #38
witte's Avatar
I replaced the coil because on deconecting 1 the engine goes and no backfire's . when deconecting the other one and reconecting the deconect one , the engine gave me backfires .
Old Oct 16, 2009 | 09:05 AM
  #39
witte's Avatar
thx
I have check the Vref , i got on the conector from the EVR 13v , i have seen that the hose DPFE intake manfold side was closed ( hose was in bad condition ) so i replaced the hose already but still the same prob . now i did a test drive whit it and when you accelerate slowly the car goes . when accelerating to heavy it backfires . i also have seen after the testdrive that i have also the codes p0135 o2 sensor heater cirquit , p0155 also o2 sensor heater cirquit and P0171 system to lean bank 1 .
Thx
Old Oct 19, 2009 | 01:52 PM
  #40
witte's Avatar
Hi all ,
problem solved , car driver back normal , no more backfires :-)
cya
