cam shaft what to choose
Old Jan 28, 2007 | 04:58 PM
milbags's Avatar
Would anyone know what cam shaft choice to use with an 1989 f150 302 with a powerdyne supercharger, msd ignition,76 mass air meter,mass air conversion kit, 185 inline fuel pump,30 lbs injectors,headers, intake,4.10 gearing. i do not want to change the stock heads yet do to they are to exspensive. i will eventually. i am going to add eldelbrock intake, upper and lower and also a 61 mm throttle bodie from bbk
would anyone know what size of cam shaft that i should choose . i still want it to be a daily driver with some pull
thanks
Old Jan 29, 2007 | 08:35 AM
s1037s's Avatar
thanks
call any of the cam tech lines, they will get you exactly what you need and will ask you more questions about intended usage and such. most have 1-800 numbers.
Old Jan 29, 2007 | 03:12 PM
Klitch's Avatar
s1037s is right on that one. your best off calling and talking to someone who's suppose to inform you of where the power curve is on each cam and what that makes it good for with that particular motor.
