Time for a new Thermostat. Stock or step down?
Old Jan 25, 2007 | 01:49 PM
DHoot's Avatar
Looks like my current thermostat may be stuck slightly open. I am going to replace it this weekend but I am not sure if I should get the standard 195 or a step down to let it run a little cooler. I have heard that running a little cooler helps with performance and life of the parts, but I do not want to set off my SES light. Any recommendations?
Old Jan 25, 2007 | 02:16 PM
These engines are designed to run at that temp. I would go back with a 195. It will be most efficient. Not like the old days when we had to try to get them to run cooler.
Old Jan 25, 2007 | 03:03 PM
chester8420's Avatar
Do what Jay says. If it was better, Ford would have made it that way from the factory.
Old Jan 25, 2007 | 04:23 PM
BLUE20004X4's Avatar
I wouldn't say they would do that chester, but at the very least the aftermarket would be all over that. The stock thermostat is fine, going from a 192(stock) to say a 180 may cause the engine to run in a closed loop- NFG unless it's warming up.
Old Jan 25, 2007 | 11:10 PM
RJP66F100's Avatar
Just curious if temp gauge was not reading normal or if heater wasn't as warm as usual.
Old Jan 26, 2007 | 08:30 AM
DHoot's Avatar
Thanks for the advise. I will stop by the Ford parts store and pick it up this afternoon.
The heat is fine. My temp does rise above the temperature symbol (about 1/3 to 1/4 of the way). My SES light is on and I can not remember the code but it had to do with the temperature and not being able to run closed loop. I think normal operating temp was right in the middle. I have also read that it could be a sensor.
I have 133k miles on it so figured it was about time to change it out anyway.
Old Jan 26, 2007 | 09:16 AM
Faster150's Avatar
cooler running thermostat is only needed if ur gettin detonation from the heads getting to hot it fixed m problem going to a 160F but my fuel milage is down. but the truck runs hella better now. i just gotta get the tune to fix the closer loop operations.
