IAC Cleaned, Still Loud Noise
Old Jan 17, 2007 | 04:48 PM
ameration's Avatar
I previously posted about an intermittent humming noise that I am getting when the truck is at idle. I was also having starting issues in the cold weather.
I cleaned out my IAC valve today and the truck starts fine now but there is still the intermittent loud humming noise and it is loudest at the air filter (I have an aftermarket intake). Will replacing the IAC stop this or is it something else? Any thoughts?
Thanks for the help.
Old Jan 17, 2007 | 05:01 PM
keith97xlt's Avatar
ive never heard of a i.a.c valve making noise. make sure you dont have a small vacumn leak somewhere. check all your intake connections.
Old Jan 17, 2007 | 05:16 PM
chiefFX4's Avatar
sounds like a vacuum leak to me. check all the connections that lead to and from the intake. my intake squeals in hot weather. the hoses have just never sealed right. doesnt bother me that much so ive never done anything about it.
Old Jan 17, 2007 | 05:19 PM
ameration's Avatar
All of the connections and hoses are on fine. It never did this in the warmer weather, do youthink it may just be something with the cold as this is the first winder with the intake?
Old Jan 17, 2007 | 05:21 PM
Quintin's Avatar
Replace it. IACs weren't meant to be cleaned.
Old Jan 17, 2007 | 05:27 PM
ameration's Avatar
I plan on replacing it but I am not paying $110.90 plus tax for one from the dealership when I can get the same exact one made by Ford for around $60 online. I just cleaned it as a temp. fix until the new one arrives.
Old Jan 17, 2007 | 05:53 PM
bullseye670's Avatar
I didn't think it was 110 bucks. Might want to double check. You can also get it at auto zone or any of the auto parts stores.
That sound, if it is the IAC is often refered to as moosing.
bullseye670....................
Old Jan 17, 2007 | 05:57 PM
ameration's Avatar
It is $110.90 plus tax at my local dealership (I need part number F65Z-9F715-EA - 4.6 L).
Old Jan 17, 2007 | 07:08 PM
way fast witey's Avatar
before you go by a new one,do you have a cold air kit on it?when i put my fipk on mine it started makin a humming noise so i shortened the iac line a little and its never made a noise since.man,i'm glad i don't live where ya'll do.my friend replaced his iac and it was $20 at the dealer here.
Old Jan 17, 2007 | 07:35 PM
ameration's Avatar
Originally Posted by way fast witey
before you go by a new one,do you have a cold air kit on it?when i put my fipk on mine it started makin a humming noise so i shortened the iac line a little and its never made a noise since.........
Yes I have one on the truck but what do you mean by shorten the IAC line a little?
Old Jan 17, 2007 | 08:37 PM
Yankee7985's Avatar
Check your PCV valve. Aftermarket ones tend to rattle/buzz with the vehicle running.
Old Jan 18, 2007 | 02:27 PM
FX4ALL's Avatar
It's probably the IAC. If the sound is still there *after replacing the IAC* then try shortening the hoses or reinstalling the black box that was there before.
*edited
Old Jan 18, 2007 | 02:45 PM
BLUE20004X4's Avatar
I would start the truck, let it run a bit and if you can, unplug the IAC, the truck will chug a lot if not die, then plug it back in, the quicker the better. Another idea is with the truck off, unplug the neg. battery terminal, unplug the IAC, then plug it back in and reinstall the neg. batt cable. I think it will reset itself, seemed to work on a 99 explorer we fixed, eventually it should stop making this noise. The new one should fix all so maybe just be patient is all.
Old Jan 18, 2007 | 07:28 PM
ok,let's use our brain here.would you rather try a $.50 piece of heater hose to sorten the iac line,or a $100 iac.its the vacuum line that runs from the intake tube to the iac.just take a little out at a time.it worked on mine and i remember several people on here a while back with the same problem and it worked on theirs.and then i'd try a bottle of seafoam in the intake.always start with the ceapest/easiest fix first then work your way into your wallet.and you can check your pcv valve by shaking it.if it rattles,or you're not sure replace it,they're only a couple bucks too.
motwnsprtn's Avatar
I had this exact same problem in the past. I had my father check into it (he is an engine engineer at Ford) with the people who work on the 4.6's. It's the IAC, cleaning won't help, it's a defect that was corrected before they even shipped all of the vehicles with that engine, but as you know, some of them made it out. Replace it...the humming WILL go away!
