Super Unleaded
Old Jan 15, 2007 | 06:08 PM
mrainey889's Avatar
I have to admit, I've wondered about this before. I leased a 2001 Ranger w/ the 4.0 Liter SOHC v-6 a few years ago. In the owners manual, in BOLD CAPITOL LETTERS it stated "Do Not Use Fuel With Octane Rating Greater Than 87. Doing So May Void Your Warranty."
It was also boldly printed on the gas cap to only use 87 Octane fuel. Consequently, I never put in gas rated at more than 87 Octane. I have no idea what the warning was all about, or why running a higher octane could possibly cause damage, but that is what the factory manual said.
Since then, I have never seen such a warning again, with the expections of vehicles that required premium fuel, such as my old '96 Z28. My current truck (1999 F-150, 4.6, 4x4) simply says optimized or some other such word for 87 octane. No warnings at all about running anything higher.
Any thoughts?
Mike
Old Jan 15, 2007 | 06:11 PM
Klitch's Avatar
Originally Posted by iziris
everyone freaks out about the expense. have you calculated what you are saving by getting the lower octane gas? like 2-5 bucks per fill up. big savings eh?
yeah, that 2-5 can mean a lot to some people... i fill my tank atleast twice a month. so thats up to $10 a mo i could save?
Old Jan 15, 2007 | 06:21 PM
kingfish51's Avatar
Heck, I fill mine twice a week.
Old Jan 15, 2007 | 09:24 PM
iziris's Avatar
Any thoughts?
Mike
if the vehicle says don't run it then don't run it but if it doesn't then go ahead...
I'm right there with you.
Originally Posted by hcmq
We need an engineer to chime in here.
From the limited research I have done over the years I have learned that it will indeed harm your engine.
On the contrary it will in fact cause MORE deposits due to the fact that it burns slower and the engine has no way of knowing that there is slower burning fuel in there. Therefor the timing is not adjusted properly so in turn you get excess carbon build up.
Other than that I believe it is harmless to use it.
my .02
peace-
well from what my mechanic told me (who has alot of experience) he had a ranger that he ran nothing but premium on and after 400,000 miles the engine finally went out. he said when he took the engine apart it was clean enough to eat a steak out of because of running the premium gas. not trying to make an argument, i could be wrong, could be right or visa versa. just throwing something in that someone that experienced told me about.
Old Jan 15, 2007 | 10:03 PM
lees99f150's Avatar
6.13 Can higher octane fuels give me more power?
On modern engines with sophisticated engine management systems, the engine
can operate efficiently on fuels of a wider range of octane rating, but there
remains an optimum octane for the engine under specific driving conditions.
Older cars without such systems are more restricted in their choice of fuel,
as the engine can not automatically adjust to accommodate lower octane fuel.
Because knock is so destructive, owners of older cars must use fuel that will
not knock under the most demanding conditions they encounter, and must
continue to use that fuel, even if they only occasionally require the octane.
If you are already using the proper octane fuel, you will not obtain more
power from higher octane fuels. The engine will be already operating at
optimum settings, and a higher octane should have no effect on the management
system. Your driveability and fuel economy will remain the same. The higher
octane fuel costs more, so you are just throwing money away. If you are
already using a fuel with an octane rating slightly below the optimum, then
using a higher octane fuel will cause the engine management system to move to
the optimum settings, possibly resulting in both increased power and improved
fuel economy. You may be able to change octanes between seasons ( reduce
octane in winter ) to obtain the most cost-effective fuel without loss of
driveability.
Once you have identified the fuel that keeps the engine at optimum settings,
there is no advantage in moving to an even higher octane fuel. The
manufacturer's recommendation is conservative, so you may be able to
carefully reduce the fuel octane. The penalty for getting it badly wrong,
and not realizing that you have, could be expensive engine damage
Here are a few pages of very good info about fuel. some of it is very technical.
www.faqs.org/faqs/autos/gasoline-faq/part1/
Old Jan 15, 2007 | 10:11 PM
00Ford4X4's Avatar
If it's free, by all means use it!
Old Jan 15, 2007 | 10:13 PM
Big Red P225's Avatar
Using too high octane fuel does ruin the engine, but it does ruin the cats. Higher octane fuel burns slower, so unburned fuel is sent out the exhaust manifold. Since your not burning all the fuel, you would get lower fuel mileage, but since this fuel is free, who cares. Problem is, the unburned fuel will destroy the inners of the cats. If you have a short lease, or live in an area that doesn't test, then burned out cats verses free fuel seems to be the real cost question.
Old Jan 16, 2007 | 04:50 AM
bradbriney's Avatar
i get it from my wifes parents.......... they have gas stations and use Super in their vehicles, at the end of the year they write it off as a business expense. So i can get super for free and they just write it off like they were using it. its hard to figure out whether to use it or not everyone says something different.
Old Jan 16, 2007 | 06:01 AM
JasonFX4's Avatar
Dont remember where I heard it, or read it, but using super in and engine designed for regular will foul the converters because of all the unburned fuel.
Old Jan 16, 2007 | 07:00 AM
jbrew's Avatar
Octane is an additive to CONTROL the burn. Some believe that octane is something to make the gas have more energy. No! Octane rather allows a
crankshaft engine to extract and use more of the available energy in the gas. Injecting water into the intake manifold has been used to boost octane rating.
Remember that all gasoline fuel has an octane rating. All gasoline crankshaft piston engines are dependant on gasoline design burn control.
Some engines need to burn the gas slower than others. From what I've read , you guys prolly already know this , good thread..
Old Jan 16, 2007 | 11:52 AM
98Navi's Avatar
This is 100% true. Newer vehicles with more sophisticated computers can tell when you are burning premium or regular, and the computer varies the timing and other factors to compensate. In older vehicles, the computers were not designed to do such, so there is no benefit. However, even if the chance of cat damage exist (and I'd bet its so minimal you could win the lottery first) you would still be better off getting free gas. A couple of aftermarket cats would only set you back a couple hundred bucks, or the equivalent of maybe a months worth of gas. I'll step out on a limb and say you'll never have a problem.
Old Jan 16, 2007 | 12:20 PM
PKRWUD's Avatar
Unfortunately, many people assume that higher octane fuel is better for all engines, no matter what. This, as I'm sure you know, is absolutely false. Ultimately, the best octane for any vehicle is the lowest one you can run without detonation (pinging) occuring.
Running too high of an octane will ultimately make it necessary to continue using that octane.
Just to clarify, it's not the fuel that increases the performance, it's the fact that the timing has been advanced. The higher octane permits this to happen. Basically, the way it works is something like this:
Octane represents a fuel's stability. When you compress an air fuel mixture, it becomes quite unstable, and explosive. In fact, this is why diesel engines don't require spark plugs. They commonly have compression ratios of 22:1 (as opposed to a stock Mustang with 9:1), which makes the air/fuel mixture so explosively unstable that it ignites itself when the piston reaches TDC.
Octane, for all intents and purposes, is used to slow down, or control the burn rate. Modifications that increase performance, such as increased compression, or advanced ignition timing, will cause the mixture to become too unstable, and pre-ignition (aka: detonation, pinging) will occur. This is when the mixture fires on it's own, at the wrong time. Severe damage will occur if left untreated. Anyway, the only way to perform the mods that increase the power is to further slow down and control the burn rate of the air/fuel mixture, and the method used to do this is increased octane.
People often think of high octane fuel as being more flammable, and easier to ignite, whereas that is actually the opposite of the truth. 110 octane race gas is much tougher to light than low grade 87 octane. BUT, because of that fact, it is the use of 110 octane fuel that permits the compression to be increased to 12:1 without melting the pistons.
Use of a fuel that has a higher octane than is required by the engine and the way it has been tuned will result in unburned deposits being created and left behind in the combustion chamber, and on top of the pistons. These deposits cause the combustion chamber to become very unstable, for several reasons, all of which will ultimately require you to use a higher octane fuel to restore stability. Among the reasons, are increased compression (the deposits take up space, and actually increase the compression over time enough to make it unstable), retained heat (deposits retain heat at times when those surfaces shouldn't, increasing the likelyhood of pre-ignition), and the development of sharp edges (like sand under the waves, deposits can be "shaped" by their environment, and can develop sharp edges, which act to the compressing mixture like a hat pin would to a balloon.
Old Jan 16, 2007 | 12:28 PM
hcmq's Avatar
I believe the only way a vehicle can "Tell" if there is high octane fuel is if it has a knock sensor. Someone smarter than me needs to answer whether these trucks have them or not.
Please feel free to correct me if I am wrong (I know you will!) but there are no other sensors that "Tell" if you have put a different kind of fuel in the tank. ECM's don't have the ability to change timing based on what kind of fuel is in the tank. Though it would be cool if it did!
Think about the logic of this thread's question: If it were as easy as some have stated here then why are there engines that require it and ones that don't? If we follow this logic we should just be able to use what fuel we want and the ECM will take care of it. But that isn't the case.
More proof lies in the fact that amoco had to pull its ads about its high test increasing power and performance because it just isn't true.
In addition, a clean engine is not a good case study. A clean engine from fuel is based on the additive package not the octane rating. Yes some brands put more addatives in the the higher octanes (IE: BP/Amoco) but most put the same engine cleaners in all octanes.
Here we are questioning the engineers who designed these engines for 87. This should be added to the oil arguement: Is it safe to use 10w-30/20w-50 because my grandfather did 30+ years ago or because an old fasioned mechanic says its ok.
Oh well maybe and engine designer/engineer will read this and set us all free!!
Peace-
Old Jan 16, 2007 | 12:54 PM
jbrew's Avatar
Yeah , on top of the block under the plenum - I believe all 97 -03's are - Idunno past that.. Neals got a good shot of it in his motor build thread..
Old Jan 16, 2007 | 01:03 PM
jbrew's Avatar
https://www.f150online.com/forums/sh...t=Knock+Sensor
