RPM's drop down when stopping...
Old Jan 18, 2007 | 08:18 PM
rmeidlinger's Avatar
One day I noticed that my PCV was making a buzzing noise. I replaced it and my truck acted exactly like what you are describing.97 4.6L
I think the PCV must have been going bad for quite a while before the spring got weak enough that the buzzing could be heard.
I knew the PCM would take a while to adapt to the new air fuel mixture. I did not want to wait so I applied the "Microsoft solution"- disconnect the battery for two minutes. Brought the in gear idle back to its steady 600rpm, where it has always been for the last 9 years
Old Jan 18, 2007 | 08:21 PM
how many miles on your truck? check the seperate emissions warranty. the EPA gets very upset when the dealers charge for emissions repairs that are covered by warranty
Old Mar 12, 2011 | 12:05 AM
blitz_'s Avatar
I hate to bump a thread this old but was your issue fixed by replacing this hose? Do you have a picture of the hose you replaced by chance? im having these same symptoms as well on my 03 f150 kr 5.4 4x4
Old Mar 12, 2011 | 11:03 PM
blitz_'s Avatar
anyone?
Old Mar 13, 2011 | 09:50 AM
dcz's Avatar
dcz
i'm having the same problem, i tend to also thnk some vacuum item, if anyone has replaced hose and solved problem please let me know
Old Mar 13, 2011 | 10:02 AM
dcz's Avatar
dcz
I also seem to notice, more when engine is warm that when i start from a stop there is a clunk type noise, i almost thought a u-joint, but it doesnt do it all the time, and not always under load, maybe related also to this
Old Mar 13, 2011 | 10:39 PM
blitz_'s Avatar
if you find the leak its going to be by pure luck, i felt everywhere and didnt feel any leaks anywhere as well as spraying throttle body cleaner all over the engine with no avail
Old Mar 14, 2011 | 08:56 PM
blitz_'s Avatar
could a bad brake booster cause this same issue if it has an internal vaccum leak?? because it only does it when I am applying the brake
Old Mar 19, 2011 | 09:45 AM
blitz_'s Avatar
I now know its not the booster as I have tested it, im still waiting to see what the fix was for this b/c I have no vaccum leak via a smoke test on the truck so all vaccum lines are good.
Old Mar 19, 2011 | 02:43 PM
shockey's Avatar
How is the PCV? You might try and clean it out or replace it. Also the IAC could need to be cleaned. And already mentioned in this thread, is the PCV hose collapsing under high vacuum.
Hope it all works out for you.
Old Mar 19, 2011 | 09:57 PM
TLCREEL@bellsou's Avatar
For those of you still having the problem with RPM's dropping when stopped. Try turning off your air conditioner.....the problem should go away. Turn on your air conditioner.....the problem returns. If that's the case, pick up a can of Arctic Freeze R-134a refrigerant from your local auto parts store (the one with the gage) and follow the instructions to charge the system. Harbor Freights carry's the 18oz can with the gage for $25.
Old Mar 20, 2011 | 04:02 PM
No, you should not attempt to charge the A/C unless you know for a fact that it's low - and you need a set of manifold gauges (high and low side) to determine that.
Old Mar 21, 2011 | 05:26 PM
blitz_'s Avatar
havent used the a/c until today and it does it when its on or off, so i dont think the a/c has much to do with it. I went by the junk yard today and pulled the entire intake tube mass air flow and all off a 5.4 navi engine for 25 bucks. Im going to convert my intake back to stock and see if that changes anything which im thinking it will. If it does im going to take the intake i bought back to where i got it from.
Old Mar 16, 2016 | 08:26 PM
Stephen Roe's Avatar
RPMs drop when decelerating. 97 F150 XLT 4x4 4.6L
Originally Posted by Bluegrass
If the converter lockup was the problem you should be able to distingish that by the way it feels with the engine trying to pull the truck with no throttle applied.
When you brake, the converter disengages as a normal function from the contacts on the brake switch signalling the PCM.
On decelleration, the PCM shuts down fuel to a low level and closes the IAC as a normal action and updates tables but is supposed to recover the idle so stalling never happens.
Something is causing this action to fail.
The 500 rpm you see is the base idle throttle stop setting without the IAC open.
Dirty/corroded connector, sticky IAC, vacuum leak under high intake vacuum conditions or no speed feed back to the PCM is a cause.
Does it do it setting still and jazzing the throttle?
I have the same problem on my truck. When I brake or just coast at low speed(a lot of stop signs), the RPMs drop to 330-650. Sometimes it dies. If I let off the brake while stopped, the truck doesn't move and the RPM's remain low. When I shift to neutral or park, the RPM's return to normal(about 800-1000). It seems to be worst when driving around town.
I'm not sure if it's related but I get this code: P0174 - Powertrain System too Lean (Bank 2).
I replaced the IAC and nothing changed. I read someone else's post that maybe the PCV has a vacuum leak or is collapsing. I'm hoping it's not the torque converter.
Old Mar 16, 2016 | 09:59 PM
Too lean is either a vacuum leak or an exhaust leak before the front O2 sensor.
