E-Fan - Single or dual??
Originally Posted by Surfjunkie44
Used in...? I'm having the similar delima as Ryan... I know we don't NEED $400 worth of 5500 cfm's blowing into our engine bay but we do NEED to get rid of those power-robbing obnoxious non-E fans.
On a side note where does Mike get off charging so much? When I saw the price tag on his e-fans I wanted to send him a picture of two of those old skool oscillating bedroom fans duct taped to the front end of my truck with a caption saying "$50 from Walmart; adds 5 to 10 HP at the wheels; it'll do".
mustang cobra, mustang GTR, mustang GT, mustangs of all types for years now. town cars, crown victoria's, minivans, taurus most every car that ford can put a 16" fan on they do. the other compact cars use twin 14" one for AC one for cooling. if fords research and design team hasnt found a reason to run 2 fans on their cars for the past 15 years i dont see how a buncha people on a message board would know better? do you?
Thanks everyone for your input...I think after hearing Joe and Faster150, Ill look into a single fan. I live in Alabama and use this truck for commuting during the week, leisure on the weekends and occasionally will use it for towing and hauling.
Originally Posted by Neal
HI!... Ya for sure go with a dual fan set-up. Just like was said previously, one fan craps out you have another for a back-up. Your single fan craps out, your screwed!!!!!!
I've got two 16" DERALE fans from SUMMIT RACING. Been running these fans for about 7 years now with no problems. Cost me about $200(U.S) for both fans 7 years ago.
Originally Posted by Ryan76
I was just on Summit Racing's website and it looks like they dont sell the dual 16" derale fans anymore. I guess if I was considering one fan, certainly dual 13" fans would work right? It says they produce 4,000 cfm.
Each one of my fans is rated at 2200CFM or 4400CFM combined. Their pretty quiet when running.
CFM isn't the only thing to consider. You need to actually use the radiator. If you're flowing 16,000CFM through a 3" diameter fan, you're not really helping yourself. If you look at the stock fan, it's got a shroud on it that forces the fan to draw air from the entire radiator. This is the same reason why 80% of the front end of the truck is ducting/venting for the radiator and the other coolers.
I would say that 2 fans of just about any CFM would work just fine. You don't need mega-CFM numbers as much as you need airflow across the entire radiator. Try to cover as much of the radiator with fan as possible. If you want to be really fancy, make or buy a setup that has a shroud on it so all radiator air must pass through the fan. Make sure it's aerodynamic though, otherwise you'll reduce airflow across the radiator at speed.
Originally Posted by SRockwood
....Make sure it's aerodynamic though, otherwise you'll reduce airflow across the radiator at speed.
I have pondered the shroud question - and my 92 already has a shroud for the belt-driven fan, so I'm figuring on a single efan for me, that's going to work with the existing shroud, so I don't have to build one and worry about electrolysis etc if I were to use aluminum, etc....
The only issue I can see is, if you were to block the sides around the fan when the fans were flush mounted, and also flush mount the material you were using for the shroud, you'd effectively only draw air through where the fan/s are - if the fan's set back as is the shroud, like the factory arrangement, you'd be drawing air across the whole radiator, as you should.
I'm figuring I'm going to unbolt the clutch fan where the assembly bolts to the pulley and remove the whole assembly, leaving the pulley and belt as they are (I assume the pulley's the front end of the water pump, anyway) and mount the efan inside the shroud somewhat, as far as is needed to clear the pulley safely.
Wire it up with a supplemental relay so it runs 100% of the time with the a/c when it's on (as factory efans do) and perhaps have the whole fan running in a failsafe mode (so if the controller fails, the fan runs 100% rather than not at all.
I don't anticipate using two fans, (could you use two in push/pull mode, one front of rad pushing, one back pulling? I had a Ford Telstar - mazda 626 - that worked that way, the front fan was right in front of the a/c coils I guess, engine called just the rear fan, I think front fan only ran with a/c- this way you can have two large fans, that wouldn't fit side by side) my truck's old, not exactly a showpiece, and I just want the better fuel economy - not to mention it takes an age to warm up, I've been planning a variation on the oh-so-attractive cardboard on the grille setup for our winter. When I fit my efan, hopefully it'll reduce or completely remove the need for the cardboard, since the fan won't be running all the time.
