The Truck Project
Old Dec 19, 2006 | 06:00 PM
csonka
Guest
Posts: n/a
Thumbs up The Truck Project
My truck is over 10 years old and is finally starting to creek, ping, rust and crumble. The age is really starting to show. Mechanically, it is one thing after the other. The body is rusting and rusting and rusting. Time to consider... something.
It only took me a second to think about what to do. Do I buy a new truck? No. We're going to undergo an overhaul. Yep, we're talking blood sweat and tears in the hope that it will be even better than when it was first assembled in the plant.
I just can't imagine what old Barney was like back in his glory days. I've driven other trucks from those years and mine is falling way behind. I don't want anything that is going to scream and race. I want it back to almost stock, but with more performance and better tuning. So, Ford fans, truck fans of all kinds, I am calling you out for your attention and insight as I make progress.
This should be fun.
-Patrick
csonka on f150online.net
Project: TheTruckProject
Objective: Complete Overhaul and Slight Restoration to Factory Condition
Subject: 1995 Ford F-150, 302 V8, 4x4, E40D, Extended Cab, XLT
Start Date: December 19, 2006
ETA: Late Spring 2007
Parts and Labor List
Exhaust:
Stainless Steel Header Gaskets
Hooker Longtube Headers, Ceramic Coated
3" DI/SO Y Pipe
High-Flow Performance Catalytic Converter
3" SI/SO Gibson Catback Exhaust **
Stainless Steel Hangers and Bolts
Body:
New Ford Body Panels (Driver Front Fender, Passenger Front Fender, Rear Cab Panel Kit, Bed, Rocker Panels)
New Paint and Clearcoat (Keep Colors)
Rhino Liner Bed
Frame Pickling and Boxing
Engine:
Complete Engine Rebuild
Engine Painted Ford Blue
Braided Stainless Steel Hoses and Lines
Ignition
Distributor
Bosch Platinum 4 Spark Plugs **
9mm Spark Plug Cables **
Intake Manifold
Throttlebody
Alternator
A/C Unit
Electric Fans
K&N FIPK **
Transmission:
Replace Automatic E40D with Manual
Fuel Delivery:
Fuel Pumps
Filler Necks
Tanks
Straps
Interior / Cab:
Door Panels
Rhino Liner Floor
Dynamat Xtreme (Doors, Roof, Firewall, Back Cab)
Leather Chairs (Bucket)
Leather Bench
Wheels, Suspension, Brakes:
31x10.5 R15 Bridgestone REVOs ***
Ranchero Shocks
Leaf Shackles
Drums
Dual Piston Calipers
Braided Lines
Final Step:
Custom Tune From Mr. Troyer
** - Indicates Part Already Used or Ordered
Log
12.19.2005 - Posted project and started parts list. Will start ordering parts and setting shop times. Need to ellaborate more on the parts list and come up with projected cost. Added Frame Pickling and Boxing thanks to CheifFX4. Have any suggestions on parts or anything?
Old Dec 19, 2006 | 06:32 PM
chiefFX4's Avatar
a far as the frame goes, id look around for someone that will pickle and box it. pickling will seal the metal and clean the frame, boxing will help with strength.
Old Dec 19, 2006 | 06:43 PM
csonka
Guest
Posts: n/a
Okay, I will look into this ChiefFX4. It really needs to be stiffened up.
Old Dec 19, 2006 | 07:07 PM
F151's Avatar
A formidable project to say the least. Sure would like to see the final cost when finished. I'll bet it will be close to new/almost new truck territory. Might I suggest going with rear disc also? And good luck with everything. especially that third pedal addition on the tranny swap.
Old Dec 19, 2006 | 10:11 PM
3304x4's Avatar
Remember to take lots of before and after pictures, and post them here for all to see!!!
Old Dec 19, 2006 | 11:37 PM
csonka
Guest
Posts: n/a
Yessir you bet! Will take all before pictures tomorrow.
Old Feb 28, 2007 | 06:27 PM
csonka
Guest
Posts: n/a
New Website:
www.TheTruckProject.com
I will link this thread.
Old Feb 28, 2007 | 06:30 PM
Jbrobeck's Avatar
Awsome, I can't wait to see the progress, for some reason I really like that body style, nothing like seeing an older truck/vehicle in pristine condition, good luck with it!
Old Feb 28, 2007 | 07:35 PM
hmustang's Avatar
Sounds like its going to be a fun project good luck to you and keep us up to date on it.
