DOHC heads on my new engine.
Old Dec 17, 2006 | 10:45 AM
built54's Avatar
So I decided since im going turbo, Id also like to go with dohc heads. What intake manifold do I use, and does the 2 valve timing cover work? Also, what year should I look for on these heads?
Old Dec 17, 2006 | 02:07 PM
01Roush's Avatar
The easiest way to go would probably be a 5.4 Sullivan, really depends on the rpm range you want to pull though. If you were planning a 6k shift point for example, the Navi intake should make much more average torque in that range. If you are running 6500 or more the Sullivan would come into play.
Old Dec 18, 2006 | 07:33 AM
s1037s's Avatar
a 2v timing cover will not work, you have to use a 4v cover. If you are building a 5.4 you can't use a 4.6dohc cover and vice versa. Have the heads inspected by a good machine shop. probably faster and easier to get a complete navi motor
Old Dec 18, 2006 | 01:53 PM
built54's Avatar
Yeah, I just wasnt sure about the timing cover... I have all the people for machine work, I build my own engines... I already have a short block built for 1000hp... Just cant decided If its worth it to go with 4 valve heads...
Old Dec 18, 2006 | 03:05 PM
s1037s's Avatar
yes it is worth it!
