BBK 75mm Throttle Body
Old Dec 10, 2006 | 09:15 PM
iziris's Avatar
looking to put a bbk 75mm throttle body on my truck. will i see any mpg diff if so how much?
Old Dec 10, 2006 | 09:28 PM
BLUE20004X4's Avatar
I was wondering about the same, all I was told was save your money for gas instead. The gains are SAID to be minimal if any. There is a trick about the TPS sensor and resetting the voltage or ???? I personally still think it may be worth while to try, we'll see what others say with them.
Old Dec 10, 2006 | 11:42 PM
KickinBlue4x4's Avatar
They are minimal. The only reason I did one on my truck was because I have the AF1. Also, If you dont port the plenum to match you arent going to gain much if anything at all.
Old Dec 11, 2006 | 09:13 AM
iziris's Avatar
any particular mods anyone would suggest i do to gain gas mileage?
Old Dec 11, 2006 | 10:47 AM
melman's Avatar
Hey KickinBlue4x4, port the plenum, Im from MO. show me . I have the 75mm throttle body but did not port the plenum. This is the first I have heard of it. A little tech. advise please .
Old Dec 11, 2006 | 11:05 AM
A mod to gain mileage from what I've seen has been by far upkeep, plugs, oil changes and of course cleaning the t-body and IAC. I also have a K&N and have to clean it at 50000 miles or so, very forgiving that way. But the real money in my opinion has been the chip, exhaust and e-fans. The 1st and 3rd have been the biggest contributers, the second is just very minor, I like loud is all. I have run 91+ octane since 2000 so in my opinion that yields better mileage and cleaner burns, added to the chip that requires 91 at least.
My thaught is since I am kinda interested in a 75 mm BBK myself, I also have shown interest in a 90 mm MAF and JBA or Bassani headers. Maybe 1 of the above gains little at all, but all of them together plus a reflash of my chip? First I wonder what porting will do for buddy with the expy since I see he has the BBK, plus a 90mm MAF. Huh? Keep posted melman or anyone that's done similar, I would like more mod ideas if worthwhile.
Old Dec 11, 2006 | 11:58 AM
Porting (port-matching) the plenum implies widening the intake hole where the throttle body bolts to, which is the plenum. I think JMC might have pics.
Old Dec 11, 2006 | 01:14 PM
Faster150's Avatar
the MAC 75mm is better due to the adjustable idle screw
Old Dec 11, 2006 | 01:16 PM
Faster150's Avatar
3.27 gears or lower
Old Dec 11, 2006 | 10:43 PM
ONELOWF's Avatar
My 75mm BBK has the adjuster screw, but I've never needed to adjust it.
Old Dec 12, 2006 | 02:24 PM
melman's Avatar
Thanks KickenBlue4x4. I will have to take a look at it the next time I take things apart.
Old Dec 12, 2006 | 03:39 PM
No problem. If you have any questions feel free to email me.
Old Dec 13, 2006 | 02:26 AM
bigtruck311's Avatar
alot of my friends that had the MAC had problems after a year or so with a vacume leak from the O rings on the throttle blades, i hear it is a common problem on the macs
Old Dec 13, 2006 | 02:30 AM
tritonpwr's Avatar
No MPG increase, no horsepower increase, nothing.
In order for a TB to do any good, the one you have must be too small and thus be causing a restriction.
If you consider that, nothing but WOT would be improved. But even for that to happen, the existing throttle body must be causing a restriction, and with a stock motor, it's not.
Oh, BTW, Mac TB's suck.
Old Dec 13, 2006 | 08:23 AM
Faster150's Avatar
funny.. my friend mark has one he sprays methanol and nitrous through and runs 20+ lbs of boost on and his holds up fine in his F150. he said personaly the MAC is better than the BBK.
