Seafoam
If you put seafoam in gas tank do you need to change fuelfitler ?
yea change it right after.
Just don't do it.
Hi.
You'll be changing a lot more than just your fool filter if you decide to use this retarded excuse for a cure-in-a-can :lol: Fr'instance: https://www.f150online.com/forums/sh...hlight=seafoam Lots of dudes & dudettes use this chit, but then again there's one born every minute, so that accounts for a lot of them :D " ~Oh, Jbrew..!!~" Gas goes in your gas tank. Oil goes in your crankcase. Air goes in your intake. Beer goes in your belly. Nothing else. Cheers :beers: Bubba |
Now you have me woried:eek:
Keep searching and you'll find a few more actually factual discussions on why it's generally not a good idea to put this (& other) stuff in your internals. Best decarb treatment is the walnut shell process used by Ford. Don't use it, & you'll have less to worry about. There is no cure-all in a container. That kind of thinking I thought went out of favour when guys stopped running around the countryside selling 'magic elixirs' from the back of their horse-drawn wagons ... but apparently not. :eek: Cheers Bubba |
Never used it in a car/truck, but it works wonders in 2 stroke boat motors and dirt bikes (especially if you run a castor blend oil). But, for boats and bikes, a can of de-carb works even better.
Originally Posted by MGDfan
Hi. I'm just getting started :lol: .
Keep searching and you'll find a few more actually factual discussions on why it's generally not a good idea to put this (& other) stuff in your internals. Best decarb treatment is the walnut shell process used by Ford. Don't use it, & you'll have less to worry about. There is no cure-all in a container. That kind of thinking I thought went out of favour when guys stopped running around the countryside selling 'magic elixirs' from the back of their horse-drawn wagons ... but apparently not. :eek: Cheers Bubba Don't let MeGaDillweed scare yuh - Seafoam's been a great product for allot of people. Hey bubba you over look something?:devil: https://www.f150online.com/forums/sh...d.php?t=263089 |
Thanks jbrew just did not want anything to go bad:thumbsup: to cold to chang filter now
a treatment every 30-40k is all u need. one treatment lasts awhile. the 4.6 does seem to burn clean. so ive only used it on cars with more than 80k. cleaned them right out never a problem.
If you run it through your tank, do what Keith said - change the filter right after you go thru that tank fuel or ASAP.
My cousin is a chevy tech and they used to offer a "3 pack" engine cleaner. It consisted of a butterfly/intake cleaning with carb cleaner, a gas additive, and a product very similar to seafoam sucked in the brake booster line. Chevy did not seem to feel this could damage anything as others here have said. I have also been a big fan of sea foam over the years and used it on probably 6-8 vehicles numerous times on each. Never had a single problem caused by the sea foam and many ran much better after the treatment.
I was hopeing to not haft to mess with fitler in the cold dont know if i can get it off and what kind to get?
Btt
I don't have the numbers in front of me. Motocraft products are choice, on the fuel filter (not oill filter) you can use Fram as well. Fram fuel filters are okay , but as far as oil filters - Motorcraft or Wix. |
Why would you have to change the fuel filter after using seafoam through the gas tank? The tank is polyethelene or some such plastic and I have never heard of carbon buildup in a gas tank. What exactly is seafoam going to dislodge that will clog the filter or do to otherwise render the filter useless?
