Engine Specifications
Old Nov 28, 2006 | 08:47 PM
91'F-150's Avatar
Question Engine Specifications
Hello all,
The x-mas season is approching and i need to find out my stock cam specs so i know what cam to get. So my question is, does anyone know the engine specifications on a 351Windsor? Any help will be appreciated. I just figured yall would be the ones who could help me the most.
Thanks,
Jeremy
Old Nov 28, 2006 | 09:14 PM
Bluegrass's Avatar
Well, listen up.
Do you know anything about your 351w engine?
To start with, it is Speed Density engine control with MAP sensing.
Injectors are batch fire configured.
You can't install a cam with very much duration that begins to lower the intake vacuum or drivability problems are a result.
Comp Cams has a cam or two that can improve over the OEM but still won't set the world on fire.
Things like idle hunting, rich running at mid throttle etc. begin to be a problem.
Discribe in more detail what your intended changes would be and what end result you are looking for.
