Cylinder 3 misfire only in the morning
I have 2002 f150 5.4 When I started up in the morning my engine shakes real bad until it gets warmed up then it runs perfect,
my engine light is on i checked and tell me that "Cylinder 3 misfire", any help
First thing I would be 'suspectiing' is a leaking fuel injector that floods the cylinder after shut-down and clears after start-up from running.
Easy to swap with another cylinder to see if the problem follows.
Check oil for the smell of gas before you start a cold engine to see if this might show.
