F-150 Keeps Stalling
Old Nov 25, 2006 | 12:12 PM
malten02's Avatar
My truck has 125,000 miles on it and it seemed to run great until last week. When i try to start the truck, it will turn over, but then stalls. If i hold my foot on the gas, it will stay running, but as soon as i take my foot of the pedal it stalls. When i do keep it running by holding down on the gas, the check engine light does NOT come on, so i dont' think it will throw any codes.
What order of parts would you start replacing?
Old Nov 25, 2006 | 01:53 PM
mgsalida's Avatar
It sounds to me like the Idle Speed Motor is bad. I'm not sure the location as I haven't had to replace mine but it should be somewhere near the intake tube/manifold connection. You'll have to remove the plastic cover over the intake manifold.
Mike
Old Nov 25, 2006 | 02:49 PM
malten02's Avatar
An update is that this morning i held the gas pedal down for about 15 minutes and when the truck warmed up, it idled correctly then. Soo, it seems to be a cold weather problem. Should i maybe clean/replace the IAC Valve first?
Old Nov 25, 2006 | 03:02 PM
keith97xlt's Avatar
take off the i.a.c. clean it good see what happens. i have a 97 with 128k had same problem few weels ago. cleaned i.a.c, she runs great now
