sea foam
Old Nov 25, 2006 | 05:56 PM
Narvous's Avatar
VUK 75 did you put it in your vac line?
Old Nov 25, 2006 | 06:20 PM
vuk75's Avatar
Yeah sucked it right in then sputtered for a min shut her down waited about 10 min fired her up sputtered then white fog for a few minutes then she was fine. running smooth amazing what a good oil change and alittle work will do
Old Nov 25, 2006 | 06:21 PM
ingrain's Avatar
not much smoke
I used seafoam through my vacuum line a few days ago and mine hardly smoked at all. Almost half a can waited and then started it and it wouldnt smoke at all at idle and only spit out little puffs when I gave it gas. Does this mean I had no buildup to clean out or what. Is my truck just special like that.....
Old Nov 25, 2006 | 10:51 PM
JasonFX4's Avatar
Originally Posted by vuk75
Well I tried the sea foam in the vaccum line and boy SMOKE is an understatement she smoked all right wow kinda took my by surprise I think my neighbor was ready to call the fire department lol. anywho after that changed the oil 5-30 synthetic. running great thanks for alll the info on the seafoam I appreciate the info
Im wondering what that does to the cat's!!
Old Nov 26, 2006 | 03:23 AM
keith97xlt's Avatar
ive used it in every car ive had. never a problenm with cat converters. not even a check engine light
Old Dec 1, 2006 | 08:20 PM
dirtdobberoffrd's Avatar
ima gonna try it on a 97 with 185000+ on it, cant hurt it maybe even help it so half a can in the vacume line then the other half in the gas tank
Old Dec 2, 2006 | 01:50 AM
jbrew's Avatar
A little warning about the gas tank procedure - It works very well indeed , it will clean the tank and pack the filter, you must change your filter pronto, to steer clear of this adverse effect. I ran 1 can per tank of high test with a new filter to increase the flow once it has gone through that tank of fuel. Swapped out with another fuel filter after and my previous filter (new before that tank of fuel) - you should have seen the crap that came out with a compressed air back-flow. The stuff works well but, you must keep this in mind. I have posted this before when someone had this prob after doing the same. A new filter then fixed his problem and supports my findings with this procedure.
Sucking up through the booster , foreign matter is incinerated - just a cool way to put it lol
Good Luck!!
Old Dec 2, 2006 | 03:09 AM
keith97xlt's Avatar
another thing ,if you have the smallest exhaust leak that stuff will find it.
Old Dec 2, 2006 | 10:12 AM
Narvous's Avatar
What about the fuelpump?
Old Dec 2, 2006 | 10:43 AM
beckerjs's Avatar
, cant hurt it
don't do it
hey bubba watch this
Old Dec 2, 2006 | 10:50 AM
bullseye670's Avatar
I put some into my 95 contour. I think it cleared out an exhust leak. I now have a slight leak.(exhust)
Old Dec 2, 2006 | 11:02 AM
beckerjs's Avatar
exhaust
Old Dec 2, 2006 | 11:22 AM
Narvous's Avatar
So you say dont use it?
Old Dec 2, 2006 | 11:49 AM
beckerjs's Avatar
not in my truck, maybe the lawn mower, maybe
Old Dec 2, 2006 | 01:43 PM
jbrew's Avatar
This guy sounds like a bonehead - I wouldn't use it in a 2005 either , get out of here idiot!!
