quick ?
quick ?
on the a/c compressior clutch plate will it hurt the compressor if i drive a couple miles with the clutch plate grinding . the bushing fell off and the cover clutch plate is rubbing on the pully . will this be ok to drive to the shop or shoul i get a tow?
Yes, it can damage the compressor, but no, you don't have to get it towed. Just unplug the compressor clutch so it doesn't try to engage.
The friction of a grinding clutch can generate enough heat to cook the compressor seal, and even set it on fire, but that's an EXTREME case and you'd have to let it grind for an hour or more continuously.
So you weren't sure about the clutch??? You need to DIAGNOSE the problem before you buy parts. Find out what the noise is; THEN you can choose how best to fix it.
Is it grinding when the clutch is DISengaged (A/C off)? If so, remove the belt & spin the compressor pulley by hand. Then try the alternator, water pump, & each of the idler/tensioner pullies. The P/S & smog (if equipped) pumps won't spin freely. When you find the source of the noise, post it here.
