Another rough idle story
Old Nov 16, 2006 | 05:07 PM
Dan_J's Avatar
Thanks Bluegrass,
I don't really know what that means but I will search for a solution. The truck still runs bad. I pulled the negative battery cable off last night while I was changing the coil pack. The CEL hasn't come back on yet but by the way it is running I am sure it is only a matter of time. The wind picked up today so it is too damn cold to do anything with it tonight. I let it run for quite a long time last night after the seafoam injection. It seemed to be running fine by the time I went out and shut her down but when I started it this morning it was back to running rough. It idles rough and while driving at slow speeds.
Wish I had a heated barn to work in...
Old Nov 17, 2006 | 02:03 AM
jbrew's Avatar
Hey Dan , did you try replacing #1 plug , check your fuses ?
Old Nov 17, 2006 | 08:46 PM
Dan_J's Avatar
I ordered a DPFE and a PCV last night. The truck seems to be idling a little better lately but still not normal. The P3401 code is a non-existant code as far as I can tell from searching the web. I know it has something to do with the air intake so I am going to exhaust all those avenues first. Some of you are probably saying that I am replacing parts when they are not needed. I agree but with over a hundred thousand miles, I have no problem replacing those parts. They have done their time and I have no problem with it.
I will keep you all updated and thanks again for all the useful input.
Old Nov 17, 2006 | 09:15 PM
jbrew's Avatar
It been a long time since I worked on a v6 - they use to have runners, I think two - like a butterfly valves in the manifolds - the runner controller use to be on the back of the motor . Maybe now they run off sensor's. I think this is a possibility , I don't know graspen lol.
Old Nov 18, 2006 | 01:51 PM
Bluegrass's Avatar
Dan,
In your bowser search bar, put on the following.....FORD DTC P3401.. and see what comes back.
It's on my paper list of Ford codes.
Your engine PCM just doesnot dream it up P3401 especially if it repeats after clearing the codes.
Hint: go the the SCT site and printout the Ford specific list.
You will see codes that you never thought existed, even though they obviously don't apply to every engine such as the differences between a v6, a v10 or a diesel etc.
Usually a v6 program would not set a code for a diesel since the list has all the codes, you would realize this.
I'm not trying to be a hard *** but to get people to think a little so they can help themselves.
If it's taken another way, so be it. Dosen't change a thing.
Old Nov 18, 2006 | 09:35 PM
jbrew's Avatar
Bluegrass quote : Today at 02:06 PM.
"I'm not trying to be a hard *** but to get people to think a little so they can help themselves.
If it's taken another way, so be it. Doesnt change a thing."
That's crap, FYI people already know how to think, sir , they came here for help didn't they? Hell, I didn't even understand your initial reply to this individual.
This is total bias , coloring with misleading intentions (your last post). Your on a legend in your mind kick - formed some stupid isolated dictatorship that allows talk down to people. You stink man. Reason why you can't smell the the chit your shoveling is because your head been up your own a$$ so long , your use to it.
You may be somewhat of an authority when it comes to vehicle repair and that's great . Straying outside of that realm into areas you no nothing about isn't to bright.
Your wrong - it changes things more than you obviously know.
Dan, don't include this poster when forming an opinion of the site. I haven't come across anyone that has been less than friendly here.
jbrew
Old Nov 19, 2006 | 12:54 AM
Bluegrass's Avatar
Bothers you don't it jbrew!
Get used to it because I'm going to bother you more in the future.
You deserve it.
You just worked youself up to it all thru the thread.
I havn't bothered you up to this point, now all that's changed, ***-hole in a barn..
Old Nov 19, 2006 | 02:15 AM
jbrew's Avatar
Well, yeah it does bother me, I resent it. Someone searching for assistance shouldn't be met with demeaning and belittling attitude , it's just foul ,what's to gain?
"A$$ hole in the barn" - ROFL - DAMN STRAIGHT! What, you have some sort of fetish
Threats Blue?
Who looks more bothered now lol
Old Nov 19, 2006 | 02:29 AM
Bluegrass's Avatar
You started it, now I'm giving it back, like I said.
You are showing what a wise punk you are.
I'm sorry you feel that way.
No need to be every body elses hero by attacking me.
I supplied useful information in every one of my replies.
If you don't like it, to dam bad.
You didn't supply anything useful but a big mouth.
WHAT CODE P3401!
Sound familuar? Just an example of shooting your mouth off before you know whats going on.
Go back and take a look again.
Old Nov 19, 2006 | 02:50 AM
jbrew's Avatar
WHAT CODE P3401!
I don't have to go back, I wasn't' much help I know . I came into the thread when he was cleaning his throttle body and gave some useful tips on cleaning before he put it back together.
Kinda escalated from there, no one was helping and I'm not familiar with that engine as I stated a few times.
Dan asked questions , I didn't ignore, I gave the best answer I had. Hoping someone else would chime in at that point.
Nope I didn't bother going back to the beginning until you mention code - so what , my bad.
Far from "punk" lol - but , if you insist. I'm in this one for the laughs now.
Old Nov 19, 2006 | 03:02 AM
Bluegrass's Avatar
jboy you better start laughing now because you got more than you bargined for.
When you attempt to intimadate me with that dirty post, you met your match.
Now what's it gong to be? Stop now or keep on going?
Old Nov 19, 2006 | 03:11 AM
jbrew's Avatar
Tell you what Blue , my points been made. So dowhatchagottado.
Old Nov 19, 2006 | 03:21 AM
Bluegrass's Avatar
I will accept that.
Let it be the last it happens.
There is no need to go this far.
I am way older than you and will not take crap beyond a certain point when personally attacked by anyone.
Closed.
Old Nov 19, 2006 | 03:32 AM
jbrew's Avatar
I will accept that.
Closed.
Right back at yuh (except for the old part)
Old Nov 19, 2006 | 04:21 AM
jbrew's Avatar
THE
END
THAT'S ALL FOR TODAY FOLKS.
