Speedometer vs GPS
OK, so here's the question: Is it off by 6mph at all speeds, or just at 60? How far off is it at 30 mph?
If it's off by 3 at 30, 6 at 60, and 9 at 90, then yes, it's a signal issue, either from the trans to the PCM or the PCM to the cluster. If it's off by 6mph across the board, either the needle slipped on the peg, or the cluster is bad.
-Joe
-Joe
Tire wear can make a difference in the speedo reading also. As the tread goes down the speed will read different.
With my Magellan GPS my speedo is one mile per hour slow. If I see 70 on the speedo I am going 71 according to my GPS>
Originally Posted by T Ellenberger
Tire wear can make a difference in the speedo reading also...
Her tires looked great for 25K and had a ton of tread left or so I thought.
I bought a new one and couldn't believe the difference in tread depth between a 'new tire' and a 'good tire' with many miles left in it.
