P0307, P1401 What are they
Old Oct 15, 2006 | 02:17 PM
150Lariat2000's Avatar
I through these two codes on my truck??? What are they please help!!!!
Old Oct 15, 2006 | 02:19 PM
SuperSport1985's Avatar
Try searching them on the web im sure someone has them.
Old Oct 15, 2006 | 02:40 PM
laj99150's Avatar
P0307, is a fault cylider C-misfire detected... (cylider7)
check your plugs and wires....
P1401 .. diff presfeedback egr circuit high input...
have your egr vavle on your exhaust checked out.. may need a new one..
Old Oct 15, 2006 | 03:00 PM
Thanks, what one is cylinder 7 on my truck....
Old Oct 15, 2006 | 03:15 PM
laj99150's Avatar
4 8
3 7
2 6
1 5
front of vehicle...
this is for a 5.4 l
Old Oct 15, 2006 | 05:23 PM
4 8
3 7
2 6
1 5
front of vehicle...
this is for a 5.4 l
Thank you very much.... Not sure what I would do without this site...
Old Oct 18, 2006 | 08:07 PM
Alright through another code, P1000.... Please help....
Old Oct 18, 2006 | 08:56 PM
Bluegrass's Avatar
If you cleared the previous codes, the 1000 code is telling you all test have not been completed.
If no other codes are present the truck needs to be driven in enough drive cycles for the PCM to looks at all tests then the code 1000 will clear if there was no further test failures.
A sprcific drive cycle is perscribed to do this but normally it will clear after a week or two of extended dtiving that hits all the points in the drive cycle.
This code can't be cleared by removing power and rebooting the PCM.
Old Oct 19, 2006 | 08:50 AM
98Navi's Avatar
p1000 code is pcm reset, memory clear
It will go away on its own when all systems (catalyst, egr, O2, Ho2s, fuel., etc....) come back online. They go temporarily offline when the pcm is reset and reboot over a few miles of driving, in Lehmans terms
