troyer e fan install
Originally Posted by Faster150
just make sure that u dont get a hole rubbed into your radiator...
Happened to me.
If the kit still uses the metal rods, don't use them...I replaced them with nylon ones. Some guys like the nylon ones, some don't. I haven't had a problem with mine.
http://www.derale.com/plastic-remount-kit.html
Not trying to hijack this thread but
....does anybody know the wrench size to get the fan off a 5.4?
Thanks!
02 F150 Super Crew Lariat FX4 White & Silver
5.4 /w Roush Cold Air Intake & K&N filter
3.55 LS
Flowmaster Cat Back
JBA Silver Cat4ward Headers
Rancho RSX's
Rancho Steering Stablizer
Hellwig Rear Anti Sway Bar
Lightning Tails
Outland Sport Bumper Guard
Hella 550's
Silverstars
Superchips 9100 Micro Tuner c/o Troyer Performance
Underdrive Pullies c/o Troyer Performance
Mag-Hytec Trans Pan & Rear Cover
....does anybody know the wrench size to get the fan off a 5.4? Thanks!
3.55 LS
Flowmaster Cat Back
Rancho RSX's
Lightning Tails
Hella 550's
Silverstars
I went to auto zone, told them i was taking off my fan and they gave me a wrench made specifically for my engine. Thats the best thing to do, otherwise your spending all day using two pipe wrenchs.
As for a tip on the efan install, make sure the probes stay in the radiator, otherwise they wont come on when your engine gets hot.
I got mine on Friday and installed them yesterday. You may want to go to Auto Zone and rent the tool to take off the factory fan. That will save you alot of time. I also didn't like the copper rods that came with the kit. Getting those little rubber things on the back of the radiator was a pain in my a**. I found the nylon zip ties to be a hell of a lot easier and much faster. Other than that...it came out nice......throttle response was much improved. Just take your time..read over the entire instructions before you start. You will be happy with the kit when you are done and get it on the road. Good luck....expect to spend about 6 hours or so if you want to do a clean install.....
ok thank you very much guys. the reason im waiting til sat is i have to go to alignment certification wed thur fri so that eats up time. the zip ties wont burn off??? may i ask which size u used?
I believe all the zip ties are the same size. They come in a kit that you can buy/order from quite a few places. I used them on my '98 and never had a problem with them, but I only had them on for around 2 years and I was only running 12" fans (less weight on the ties and it was on a 4.2L).
