4.6L V8 No power??
Old Oct 7, 2006 | 04:14 PM
ducati648's Avatar
4.6L V8 No power??
My 98 f-150 has the 4.6 v8 and for some reason it has no ***** at all! my dad's f-250 is much heavier and has the 5.4 and the difference is incredible, (a little understandable because of a bigger engine but then again the truck is heavier) and it does burn a little bit of oil, because it sure as heck doesn't lose it, but i don't see any white smoke...anyone have any ideas?
Old Oct 7, 2006 | 04:23 PM
sean_somer's Avatar
change spark plugs, oils, etc
Old Oct 7, 2006 | 06:05 PM
Faster150's Avatar
my 4.6 hauls *** your truck probabaly just need a tune up.
Old Oct 7, 2006 | 08:32 PM
iain walker's Avatar
I agree
I also have the 4.6 and it is a little monster, you probably just need a tune up.
Old Oct 8, 2006 | 05:14 PM
ducati648's Avatar
yeah i'll try that but i mean i have changed the oil and everything, sparkplags i have yet to check because they are so hard to reach down there, but i'll check them
Old Oct 8, 2006 | 06:33 PM
ducati648's Avatar
WOW! i just tried to get my plugs out...i don't think triton could have done a better job of hiding them in there...the back ones are almost impossible to reach! holy ****....
Old Oct 8, 2006 | 06:37 PM
worland's Avatar
The 4.6L is a good engine, but it's pretty gutless compared to the 5.4L. There is a huge difference in power between my '97 SCab 4.6L and any 5.4L I ever owned.
It takes me about 4 hours to change the plugs and wires on a 4.6L. Of course, if you have to break up a lot of crud and blow it out to get to the plugs, it will slow you down. OEM plugs weren't platinum plated on the outside when your engine was made and they are prone to rust/corrode into dust. Even with a tune up, I wouldn't expect any major increase in power.
Old Oct 8, 2006 | 06:53 PM
Bartak1's Avatar
Faster, Im curious what kind of numbers you are running in the 1/4 mile, or putting down at the rear wheels...Do you have anythink like that? What mods do you have too?
Old Oct 9, 2006 | 01:21 PM
Bent6's Avatar
25 Year Member
What gears are in the rearends? I high numeric gear (3.73, 4.10) is going to feel much more peppy than a 3.08 or 3.27. For me, 3.55 is about perfect with 31" tall tires. The height of the tires also effects the effective gear ratio. My 4.6 is not peppy or fast but does fine even pulling about 6000lb. of trailer.
Old Oct 9, 2006 | 01:31 PM
chrism9232's Avatar
change your fuel filter most people forget to do that and use a good fuel system cleaner i like chevron with techron you can get it places like walmart
