engine acting up!
Old Oct 2, 2006 | 07:51 AM
csf150's Avatar
engine acting up!
i have a 97 f150 5.4L and in the morning if i hit the brakes (usualy have to hit the brakes a bit harder then normal stoping) the engine starts to spuder and spit, but if i put it in nutural and rev the RPM's it stops and flys right untill i hit them again. it acts like that untill the engine starts to warm up. thanks for your help.
Old Oct 2, 2006 | 11:58 AM
jbrew's Avatar
Change your fuel filter - Seafoam your fuel injectors and upper throttle body - lookup "Seafoam" with the search feature within this forum.
Old Oct 2, 2006 | 02:44 PM
csf150's Avatar
where do i get sea foam and how do i use it the best?
Old Oct 2, 2006 | 04:58 PM
Bent6's Avatar
25 Year Member
It sounds like there may be a vaccuum leak in brake booster, or the lock-up torque converter is dragging.
Old Oct 3, 2006 | 09:25 AM
csf150's Avatar
if it was a leak why woult it stop when the engine is warm???
Old Oct 3, 2006 | 09:41 AM
Bent6's Avatar
25 Year Member
A warm engine would have less issues running in a lean condition, as you may have if unmetered air is entering through a vacuum leak.
http://www.startribune.com/131/story/491183.html
