5.4 Tapping noise
5.4 Tapping noise
My 2005 F-250 5.4 about 17000 miles, has developed a tapping or clicking noise. It almost sounds like an exhaust leak, but only occurs when the engine is warm. Generally does not make the noise around town unless you get on it, but on the highway or when pulling a load it will start making the noise especially while going up a hill. It is at the Ford House right now, but they have not called me since yesturday morning for noise clarification. Getting worried now.
Any ideas as to what this might be?
Thanks.
Thanks.
Thanks.
Thanks.
New engine won't be out of my pocket, that sucker has a 60,000 mile extended warranty. I normally run 87 octane in it at home, but have been running 88 in it while in Wyoming. It was here that the noise began, I guess it could be the difference in fuel quality. If it is spark knock shouldn't the knock sensor stop it? It runs ok, not any worse that normal. Needs some assistance from Mr. Troyer.
Originally Posted by cskrmetti
My 05 and father in laws 06 both have really loud ticking injectors, could that be it?
Hmmmm...It seems strange that the ticking would start after going up an octane point from 87 ro 88. How long has this been going on? Do you think you may have gotten some low quality gas or bad gas?
Guess I'll let you know what the dealer says.
I have a 06' and it has been making a ticking sound when it is warm. I took it into my ford dealer and they had a look at it and they came to the conclusion that the catalytic covertor is leaking or something. I actually get it replaced tomorrow and i am hoping that the problem is fixed. I am kinda regretting trading in my 03' F150 that baby had no problems. My 06' is 2months old and its been in twice already!
Well the Ford house couldn't make the sound occur. Damn thing will make it for me, but not the people who might be able to diagnose and fix it. Guess I'll drive the **** out of it untill it falls apart or will make noise for them. Frustrating.
They did day it should not fall apart.
I don't think it is the converter as the noise seems to be coming from the driver's side manifold/ head area.
When i brought my truck in it wasn't making any sort of noise, so i suggested to the dealer i go drive it for 30minutes to get the engine warm. Sure enough i come back with the truck 30min later and it was ticking away. The shop foreman heard the sound and thought it could be either the cam phasers or the convertor. The sound to me sounded like it was coming from the passenger side of the engine compartment. When they got it up on the hoist they decided it was the convertor. I guess we will see when i get it back today.
That is the odd thing about mine, if I go drive it enough to make the noise it will stop while in town on the way to the dealers. At least that is what it has been doing prior to my taking it to the dealer. Cam phasers huh? Sounds like that could be a problem I might not want to have on my way back to Texas in a few weeks. Lots of long lonely stretches between here and there. Guess I’ll see if I can make it sound off for them next chance I get. Thanks for the info.
My truck is at the dealer today for a rattling or ticking sound that occurs between 800-1200 RPM's. They told me today that it is coming from the timing belt and that they are installing some kind of kit.
Thanks for the info blue. I don't think the cam phaser is the problem as it does not go away, noise goes all the way to shift at WOT and should stop about 3000 RPM according to this quote from Quintin.
csk-I don't believe the timing chain is the issue as it generally can not be heard until engine is at full operating temp, at speed (over about 1800 RPM) and uder a load such as pulling or going up a hill. Hope you rissue is resolved though, thanks.
Originally Posted by Quintin
Faulty cam phasers usually get louder as engine temperature increases, and the noise goes away above 3000 rpm or so.
