Airpressure for my tires
I have a 99 f150 5.4 V8 engine. I also have a towing package.
What should I have my front and rear tires tire pressure set at???
I drive 55 miles to ork and 55 miles back.
Originally Posted by dizzy2006
with stock tires you should just have your tires set at the recommened factory level, if u want the pressure to be more stable then you should consider filling them with nitrogen instead.
-Joe
Sometimes, they just look too low. Someone had them filled at 27, and I aired them to 35. But I always wondered about the front tires since they take so much weight. Especially since I park my truck at an incline.
Any tips for that?
Any tips for that?
Any tips for that?
Any tips for that?
Originally Posted by chester8420
If your truck is not loaded, I would recommend sticking with what the tire says. Most say between 32 and 45. I keep mine at 50 or so cause it makes it easier on the tires to handle more weight. But if your truck doesn't have a lot of extra weight, or you don't haul much, I'd just stick to what the tire says.
Thanks, I have no heavy loads nore do I keep anything in the back of my truck. My tire says up to 44 psi, so I can have it around 40 psi and it will be fine, right? It will help my gas too right?
