Flow Master
Old Sep 19, 2006 | 11:09 PM
grant5127's Avatar
Flow Master
I have a issue with carbon build-up in my intake behind the butter-fly in the throttle body... My dealer claims it's due to the low restricted muffler.. claims the system needs back pressure to function properly Any thoughts on this ? it's a 05 F150 4.6L 13K miles.......Thanks----
Old Sep 20, 2006 | 08:04 AM
MGDfan's Avatar
Well, since it's a SlowMaster, you don't have that particular problem
And, all kidding aside, it's BS.
Old Sep 20, 2006 | 08:57 AM
allrsdup's Avatar
thats total b.s.
Old Sep 20, 2006 | 12:04 PM
racerf150-2's Avatar
its bs (they have a "special" coating behind there thats supposed to resist carbon build up) it doesnt work worth crap. just get some seafoam (spray can type) take your intake off and clean it. just let the seafoam evap out the tb for a while before u run it again
Old Sep 20, 2006 | 02:15 PM
built54's Avatar
I cant believe they told you that... thats just BS. That is from a mixture of the egr, and the pcv system... Nothing to worry about, but it wouldnt hurt to clean it.
Old Sep 20, 2006 | 04:28 PM
chester8420's Avatar
I would say BS too, but my throttle started sticking at idle after I had a really bad exhaust leak. It's been sticking ever since, but I feel like the stop screw just needs adjusting. It's probably letting it close too far.
Old Sep 20, 2006 | 04:36 PM
ws6_guyscrew's Avatar
hmm my F250 running the American Thunder si/do system has no problems, but i'm with everyone on its b/s
Old Sep 20, 2006 | 04:40 PM
All the Flowmasters being run, you would think this would be a common problem. I have 33,300 on mine with no such problem. Wait, maybe that is why the dealer had to replace my throttle body at 1600 miles. Sure glad he didn't see the Flowmaster!
Old Sep 20, 2006 | 09:22 PM
grant5127's Avatar
Thanks All..... I trust users and believers before I'd trust the punk-*** @ my local dealer What about blocking off the egr??? I really don't like the idea of my engine eating its own ****.......
Old Sep 20, 2006 | 09:24 PM
It's a waste of time. It doesn't decrease fuel economy. And it doesn't decrease power. If you disable it, it will increase the engine's harmful emmissions output at cruise, so why bother?
Old Sep 21, 2006 | 12:20 AM
built54's Avatar
agree^ ...even though mine is blocked off.
Old Sep 21, 2006 | 11:38 AM
ofcoarse the techs at a dealer will hate your cool mods and say anything to possibly make you remove it, especially if your truck is better than theirs
EGR better leave alone it will smell terrible when you fly by someone
Old Sep 21, 2006 | 11:44 AM
built54's Avatar
You cant smell my exhaust at all, smells clean as an air freshener... ok maybe not that good, but you cant smell it.
Old Sep 21, 2006 | 11:56 AM
02SCrew4x4GA's Avatar
+1. I removed my EGR system on my 00 Lightning and it didn't smell at all. I did see a 1 mpg drop on highway miles. The EGR is only used to pump a bit of exhaust gas in the cylinder to cool the temp a few degrees. Supposedly giving you better gas mileage.
Old Sep 21, 2006 | 12:57 PM
Mine smells like raw fuel when it's idling.
