MSD Ign Coil Packs vs OEM Ign Coil Packs
i was thinking about changing my coil packs and was wondering if it was worth going with MSD or just stock and what would be the advantage of going with MSD.
Im guessing the MSD's are cheaper than stock ones, so I would probably go that route. They are a little higher voltage than stock ones, .
I just installed Accel coil pack, and got them for 55 bucks each at Jegs. Cheapest I have ever seen them...
i can actually get the motorcraft for about 30-35 a piece and the msd would run me about 50-60 a piece. i was just wondering if it was worth going with the higher end. notice any diff with aftermarket coil packs?
If you can get the OE packs for 30-35 a piece I would just do that. Your not going to tell that much of a difference between OE's and MSDs or Accels. Unless your modded big time. If your stock, or just a few little mods, OE's will work fine.
