Throttle hard to open when running
Old Sep 13, 2006 | 11:22 AM
jondowd's Avatar
Hello, I recently bought a 2002 Ranger 2.3, 5 speed, AC and the 'Check Engine' light has been on. The code says 'Intake Maifold Runner' and the dealer's mechanic found a cracked vacuum hose - replaced it and reset the OD and the light is now off
However... Now the throttle is pretty hard to open - like it's stuck, causing the truck to lurch uncomfortably. I thought perhps I could lube it or replace the cable. But the problem only exists when the engine is RUNNING! Throttle is free as a bird when the engine is off !
Is this some vacuum thing? Can I fix it without going back to the dealer?
Thanks.
Old Sep 13, 2006 | 11:39 AM
beckerjs's Avatar
this happens after someone washes the engine down. take a can of your favorite lube and squirt some on the throttle shaft bushings, should fix it right away.
Old Sep 13, 2006 | 11:47 AM
jondowd's Avatar
No. like i said, it is smooth when the the egine is off. it's not from friction
Old Sep 13, 2006 | 11:52 AM
Amerimutt's Avatar
Do you have cruise control?
Old Sep 13, 2006 | 12:17 PM
beckerjs's Avatar
my bad. a little lube can't hurt
Old Sep 13, 2006 | 12:21 PM
Peacemaker's Avatar
If you don't get an answer here, or figure it out on your own, I'd have it towed to the nearest Ford dealer and let them fix it. That's a dangerous problem you have there. Just trying to keep you and others on the road safe.
Good luck with it.
Old Sep 13, 2006 | 12:42 PM
GIJoeCam's Avatar
The extra pressure on the throttle blade due to the vacuum behind it with the engine running can cause it to get sticky in the bushings it rotates in. Lube it up, and if that doesn't do it, replace it. It's only 4 bolts.
-Joe
Old Sep 13, 2006 | 12:47 PM
jondowd's Avatar
Good luck with it.
Actually, I must apologize. The problem seems to be sticky opening throttle whether it's running or not (yesterday seemed to be free when it was off, but I was wrong). So it is a friction thing - not vacuum related as I first said.
I sprayed some aerosol lithium white greese on the outside, no remedy. Should I take the air intake duct off and try spraying the inside?
Thanks.
Old Sep 13, 2006 | 12:53 PM
beckerjs's Avatar
wd-40 told ya
Old Sep 13, 2006 | 12:57 PM
jondowd's Avatar
wd-40 told ya
Is that 'Yes. take it apart and spray it on the inside' ?
Old Sep 13, 2006 | 01:16 PM
beckerjs's Avatar
On mine, after a couple of spray downs at the car wash the throttle stuck at idle. One shot on the outside did the trick. Try a thin lube that will work its way in. Avoid lube from the inside, don't want that stuff to collect dirt and grind itself in.
Old Sep 13, 2006 | 02:27 PM
NKENN's Avatar
Maybe I'm missing something here but, after the dealer worked on the IMRC the throttle started sticking. Since they are both assoiated with the intake manifold and since the problem started after the dealer worked on it, I would inspect it closely to see what the dealer may have "screwed-up".
Old Sep 14, 2006 | 02:22 AM
jondowd's Avatar
Spraying lube on the outside of the the throttle body didn't fix my problem as the inside has some black carbony, sticky stuff that was keeping the butterfly from opening freely and yes, this was worse under vacuum. I scraped the edges of the butterfly and throat of the body with a knife and sprayed WD-40 all throughout and that made it all well.
Old Sep 14, 2006 | 03:44 AM
buckdropper's Avatar
From: south western NYS Latitude: 42.34 N, Longitude: 78.46 W
Its the power of WD40!!!
Old Sep 15, 2006 | 01:02 AM
snappylips's Avatar
Originally Posted by jondowd
...the inside has some black carbony, sticky stuff that was keeping the butterfly from opening freely. I scraped the edges of the butterfly and throat of the body with a knife and sprayed WD-40 all throughout and that made it all well.
To avoid getting dirt buildup due to spraying lube in that area, next time try using some throttle body cleaner instead. No residue left behind.
SL
