No crank,no fun
No crank,no fun
Hello, I'm a new member with a 2000 F150 4.6v8, 100,000 miles on a clean and great looking truck.I just bought it about a month and a half ago and love it . I went to start her up today and NOTHING happened when I turned the key. I have full battery power ,all the bells and whistles lit up ,so I am at a loss at why it won't crank. This is the first time it has done anything like this, it has been starting and running great.Any ideas would be welcome .Thanks and glad to be a Ford member.
Do you have a keyless car starter?
Try turning your truck on and off several times (like 6 or 7 times) wait 30 seconds then try to start. Never had this problem myself , but read posts of people trying that method and it working.
Manually turn your motor by pulling on your surp belt or use a breaker bar on your crank bolt. Then try to start.
Check your cables to your starter - disconnect your battery first.
Check all your fuses - even the two 75's on the firewall by the battery, if your model has these.
If there has been no prior evidence of failure then one of these suggestions should help you.
Hope that helps.
Hope that helps.
I will suggest getting a rubber hammer or block of wood and rap on the starter to see if it has froze up. If nothing still, check the connections and make sure you are getting 12v to it. If if your getting 12v and still nothing and you have tried the suggestion above you might want to take it off and have it tested. Not too falimiar with these trucks(security systems), but have done lots of troubleshhoting on my Corvettes.
my truck did the same thing about a month ago. i got home from work, shut it off, then remembered that i forgot to go to the store so i tried to start it and nothin. it had power but wouldnt crank. i changed the solenoid on the firewall and nothin. started to disconnect the starter to change it and noticed the ground wire was rusted through where the coating doesnt protect it right at the starter. so i fixed that and changed the starter since it was halfway off and cause i had to beat on it a few times to get it off. works great
I would also check to make sure the PATS system is functioning properly...the theft lamp should go out after three seconds when inserting the key....if it continues to blink or is flashing rapidly a problem is there...
I have a feeling that's what it is too. when I went under the truck ,there seemed to be a bit of bare wire poking out of the wire wrap right at the starter connecter. Thanks
Ive had a 97' and now an 02', same problem, terminal rots off the end of the cable. Theres enough slack to clean the end and put a copper/solder type end on it, then pack it with dilectric grease and re-install. Im going to fabricate a shield for that side when I get some extra time. And of course, disconnect the battery before repairing.
I haven't had to dig into my 02's cab wiring much (yet); so somebody tell me if I'm off-base.
What I'm wondering is whether or not a "neutral safety" or "clutch safety" switch is involved. Been there done that, with my old F100 and both the Chevy trucks between that one and my "new' one. The neutral safety switch slipped out of adjustment on both the auto-tranny-equipped F100 and the first Chebbie; and the clutch lockout switch failed on the 5-speed '91 Silverado after 14 years of banging through the gears. Under the circumstances, that'd be my first check; unless the PAT or ECM handles that nowadays?
Secondly, I've had trouble with no less than 5 tilt-columns (cars and trucks from all the "big-three" automakers). Usually, the vehicle won't start with the column tilted either all the way up or all the way down. In fact, on the present F150 (2002); I can't get the key rotated all the way to the "OFF" position (and out of the lock) unless I tilt the wheel almost full-up.
I used to call that second problem my "Okie Anti-Theft Device". (Apologies to all the Oklahomans out there)
The problem with my " No Crank " problem turned out to be my
"Neutral switch" . All fixed and ready to go .
Thanks for the ideas.
( right on Desert Dawg )
