Pin hole in head
Pin hole in head
I have a 1999 F 150 with the 5.4 V8. I have a pin hole in the right side head below the upper radiator hose inlet. Any ideas on a fix? I do not know if I want to spend $2000 plus on a truck that has 147,000 miles on it. Does anyone know a good place to find a remanufactured head and what they cost?
You might give this a try.......The Head Gasket Repair stuff
http://www.barsproducts.com/product.cfm?id=14
Follow the instructions. Exactly.
You can get at Autozone, Advanced Auto, Pep Boys, etc..........
Worked for me.
Worked for me.
Pin Hole...
Jmc 's answer got it right.When working for John Deere Heavy Equip.Dealer i had an oil leak right behind the motor I.D. tag.Block was about 1/8 3/16 maybe.Drilled and tapped and locktite small allen set screw in it.Max pressure on oil can go 80psi,a lot more than water pressure.It never leaked or came out. DANA
HI!... From the sound of what you explained, it's not the head at all. Sounds like it's leaking under the thermastat housing.
Or is it here :
Or is it here :
