Plugs and wires
Plugs and wires
I am going to get new spark plugs and spark plug wires soon is there anything else anyone would reccomend changing at the same time? It's on a 98 4x4 with 123000 miles on it.
Plug wires
Sounds like a good plan. I dont know what engine you have but if its the 5.4 make sure to spray some penitrating oil on the plugs ffirst and when you take them out turn a quater turn then back it off. Keep repeating that so you dont break a plug off in the head. When you put them in make sure that you use antisieze compound on them. If your gun hoe you could look for an upgrade to your coils if you had the 4.6. Hope i helped you.
