5.4L swap into a 98 f150 with a 4.6 questions
ok i have a 4.6L in my truck now, and i found a 2004 3 Valve 5.4L Triton under 1,000 miles. what would i need to do to swap it into my 98 f150? will a 2003 motor even fit in my 98?
Originally Posted by azreael344
For the 3valve engine you would need the computer, entire wireing harness from the 2004 truck, and an in depth knowledge of the wiring of both vehicles to make it all work. you can use a 2003 5.4L just fine, you can even use your existing harness and computer. You would just need a chip or a tuner to make it run right.
