code help
Old Jul 19, 2006 | 06:08 PM
inspector99's Avatar
code help
1996 f150,4.9 6 cyl
codes p1130,1150,0385,0171,0174,1507,
what should i try fisrt?
Old Jul 20, 2006 | 12:42 AM
BlueOvalFitter's Avatar
Sounds like you have a vacuum problem.How does the engine run,very rough?
Old Jul 20, 2006 | 10:21 AM
it doesnt run rough all the time,idles pretty good for awhile then acts like its only hitting on 5 cylinders
Old Jul 20, 2006 | 07:31 PM
ok,i changed plugs,cleaned maf,iac,runs a lot better.engine light hasnt come on yet,but i get codes pending ,p0171,p0174 and p1401,system too lean and differential press feedback egr circuit high output .ANY IDEAS?
Old Jul 20, 2006 | 09:46 PM
DPFE sensor is bad.Replace it.
Old Jul 20, 2006 | 10:55 PM
thanks for your help Blue,is there a way to bypass the DPFE until i get a new one?Ford garage here had to order one.I read somewhere online that you can do something with the hoses,but im not sure how to do it.
