need help on fuel filter removal
Originally Posted by swolehead1
ok so i pussed out on the hack saw deal and took it up to a local jiffy lube that said they would do it for 20$. And they hacksawed it off and replaced it LOL.
Finally! What I do is,every oil change I spray the clips with Deep Creep.Its part of my oil change maintenance.I also lube the door hinges,spray in the doors where the dome light/ajar switches are,grease the front end with a grease needle.....you see where i'm going here.If you keep the fuel filter clips lubed you might not have this problem again.
