Ive got major problems
Old Jun 29, 2006 | 08:44 PM
1fstford's Avatar
My 60' time is 2.38
Old Jun 30, 2006 | 03:03 AM
Faster150's Avatar
Originally Posted by 1fstford
My 60' time is 2.38
i pulled a 2.21 60ft on stock general tires with a 3.55 LSD and i was spinning terribly. no transmission mods or anything.
Old Jul 1, 2006 | 12:52 PM
fasterhorses's Avatar
As BrotherDave said "sweet spot". Yours has moved since you installed gears. You need to shift at a slightly lower rpm. Experiment, you will re-find that spot when you shift and the vehicle surges ahead as oppossed to waiting too long and getting a little fade. You also need to reduce wheel-spin at launch with LS or wider tires, something. Those 4.30 gears will pop you out of the hole like a rocket when you get it right. Good Luck
Old Jul 1, 2006 | 02:54 PM
BROTHERDAVE's Avatar
25 Year Member
60 foot before gears and after gears.
Old Jul 3, 2006 | 01:28 PM
1fstford's Avatar
before 2.7, after 2.38
