Best Method to Wash Engine?
Old Apr 30, 2006 | 01:27 PM
chester8420's Avatar
Originally Posted by 98Navi
Is getting a little dirt off worth $2000 to anyone here?
I agree. There's no logical reason to wash the engine anyway. And who cares what it looks like? That's what the hood is for. If you wet your engine, you're asking for trouble. But.. If you can afford it, then by all means- Go for it!!
Old Apr 30, 2006 | 01:41 PM
SSpiro's Avatar
I've been doing it for years... Cover the important stuff, degrease, and rinse off. Wipe everything dry, then start engine and let it idle.
Knock on wood, everything has always been great.
Old Apr 30, 2006 | 07:13 PM
f-150sport03's Avatar
See the General Care and Detailing section. There's a lot on engine cleaning there.
Old Apr 30, 2006 | 07:20 PM
lees99f150's Avatar
Originally Posted by kretinus
I spray everything down with Malco Red Thunder (1:2) let it set a few and then wash everything down with a 1300 PSI washer using a 30deg tip, never had any problems with it.
thats because you don't have your spark plug in holes on top of the heads.
Old Apr 30, 2006 | 11:54 PM
redracer's Avatar
Don't Do it!!! but if you must... use a rag(s) dampened with a mild cleaner and wipe it clean.
Old May 1, 2006 | 12:35 AM
nsweeney's Avatar
call me un-****, but i've never even thought about cleaning my engine. washing the dang body twice a year is plenty for me.
Old May 1, 2006 | 02:32 AM
Yeah, if that often.... It just gets right back dirty again
Old May 1, 2006 | 05:16 AM
Squink's Avatar
Though I have not had a reason to wash the engine of my 05' f150 it's still pretty clean. I've washed the engine of every other car I've ever owned, I just make sure the engine is running while and after I am washing it. I've never had a problem with misfireing or not starting.
Old May 2, 2006 | 07:26 AM
squared80's Avatar
I've used a Scunci Steamer (sp?). Works like a charm. Very small steam spray so it's easy to control where it is going.
Old May 2, 2006 | 09:05 AM
novapwr's Avatar
Cleaning Engine
I have noticed that more dirt gets up into the engine bay area on this truck ,06 F-150 , than any other vehicle I have ever owned. Never washing it may be an option for someone living in a non salt and ice melting chemical area, but around here you would certainly have a very rusted engine bay in a short period of time. Like to hear how the pressure washing works out on the new trucks. Also, has anyone tried to seal up the engine bay area better, especially around the scant inner fenderwells?
