Engine replacement
Old Apr 16, 2006 | 08:07 PM
sjones105's Avatar
Engine replacement
I have a 99 F150 5.4 ext cab that most probably will need the engine replaced. Can it be replaced straight up by a 2004 3 valve 5.4 or would it require modifications such as wiring harness, computer etc. Thanks for the help.
Old Apr 16, 2006 | 08:50 PM
KickinBlue4x4's Avatar
I do not think the 3v would work...
Old Apr 16, 2006 | 09:08 PM
ws6_guyscrew's Avatar
yeah will be complicated I dont think it will work. Just get another 5.4L and mod it up with heads and cam you can probably get it to 350 h/p
Old Apr 16, 2006 | 10:15 PM
assasinator's Avatar
the 5.4 3v will work fine. there are a few mods, but it and all ford MODs will plug in. you will need a 75mm manual cable throttle body and adapter plate.
eliminate cmc plates, etc. your pcm will control it. no vct, but it will still make plenty of power.
the limit is probably 400 rwhp @ 6900 with appropriate forgings. without VCT. 2v is a joke compared to 3v or 4v. if you use it for towing, optimize it for that.
Old Apr 16, 2006 | 11:25 PM
If it were me I would contact JMC or Neal, before doing the swap, they would know what would be required.
Old Apr 17, 2006 | 10:41 PM
sjones105's Avatar
Thanks for the responses. I found a good deal on a complete used 5.4 3 valve engine and was hoping that I could just pull my seized 2 valve and drop the 3 valve in.
Old Apr 18, 2006 | 11:17 AM
mysticslobra's Avatar
It wont be that easy. The computer and wiring stuff will surely cause you a few headaches.
