Low fuel hesitation
Old Apr 7, 2006 | 08:43 PM
shanway's Avatar
Unhappy Low fuel hesitation
I have a 04 Screw 5.4. Here is my problem...as soon as my low fuel light comes on or shortly before, when I take off after a stop the truck hesitates a few times or jerks. It almost feels like I am running out of gas or the truck is not getting fuel. It will do it for a few seconds and then run fine until I stop and try to take off again. It will continuously do it until I fill up which is right away since the problem is obviously annoying. My thought was the low fuel light was coming on late and maybe I am almost out of gas, but this is not the case. Does anyone have any suggestions? I have changed the fuel filter but that did not make a difference.
Old Apr 7, 2006 | 08:49 PM
oldnnew's Avatar
Ummmm....don't run the tank that low?
Old Apr 7, 2006 | 10:45 PM
AAlmeter's Avatar
Condensation (debatable) or sediment at the bottom of the tank (more likely)
Old Apr 7, 2006 | 10:56 PM
projectSHO89's Avatar
Check for a clogged pickup screen on the fuel pump.
Steve
Old Apr 8, 2006 | 05:08 PM
shanway's Avatar
Thanks for the advice AAlmeter and projectSHO89...I will check into both. Appreciate the sarcastic remark oldnnew...have another
Old Apr 8, 2006 | 06:00 PM
temp1's Avatar
Actually its not that sarcastic, todays fuel pumps are usually inside the gas tanks and the fuel cools them not to mention that the fuel pump can lose prime.
http://www.athomemechanic.com/archiv...your_fuel.html
Old Apr 8, 2006 | 08:02 PM
tomlin's Avatar
Try not running it that low. The fuel helps cool the pump and more than likely you are losing prime do to low fuel. Keep running it that low and it will eventually burn up the fuel pump and leave you stranded. I have ran mine uncomfortably low a few times and never had the low fuel light illuminate. It must light up when the tank gets REAL low.
Old Apr 9, 2006 | 12:34 AM
AAlmeter's Avatar
Yup. Some cars(I want to say GM's Camaro/FB/etc line) will burn up real quick without the fuel to cool it.
Old Apr 9, 2006 | 09:47 AM
PONY_DRIVER's Avatar
Occam's razor
Old Apr 10, 2006 | 11:39 AM
Clifford f150's Avatar
OK, so I'm a spelling geek
OK, so I was looking at the At Home Mechanic link referenced here, and was wondering if anyone else noticed the following: "if your car was sold in the Untied States"
Which of the states are untied? Maybe Hawaii and Alaska, since they aren't connected to the rest?
OK, in all seriousness though, +1 for not running it so low. It does make the fuel pump run hotter and does concentrate any sediment which may be in your tank, making your pump work extra hard.
Old Apr 10, 2006 | 11:58 AM
chester8420's Avatar
I run my gas tank to below "E" 3 times a week. It doesn't hurt it.
Old Apr 10, 2006 | 12:37 PM
SlammaJamma's Avatar
Ahh, dont run ur tank that low man, i stop mine at a quarter tank at the lowest, you're sucking up trash from the bottom of the tank.
Old Apr 10, 2006 | 01:00 PM
What trash? It always draws from the bottom of the tank anyway.
Old Apr 10, 2006 | 04:07 PM
jbrew's Avatar
lol
