E-fan question.
Old Apr 3, 2006 | 10:56 PM
fordninja's Avatar
E-fan question.
Does anybody know if the e-fan controllers you can get at the local parts store have a hookup for the A/C? If they don't, how can I make it come on when the A/C is turned on? Thanks for the help!!
Old Apr 3, 2006 | 11:09 PM
PONY_DRIVER's Avatar
I don't know what kind of e-fan controller you're speaking of, but Troyer Perfomance sells his for about 25 bucks IIRC.
Old Apr 3, 2006 | 11:28 PM
SSCULLY's Avatar
Same Question as PONY_DRIVER
What is the mfgr of the E-Fans that you have isntalled ( FAL, Troyer, self made ?).
I know Mike's kit has the instructions for adding in the second fan controller, that is for when the temp rises another 10*( or what you have the controller adjusted to ) , or when the AC is truned on.
FAL VSC runs both fans at 60%, and then when the temp rises 10* ( fixed ) the fans run at 100%. The AC when turned on, cycles the fans at 60% regardless of what the temp currently is at.
There are several other mfgrs of controllers, which should have both POS and NEG triggers for the AC built into them.
Old Apr 4, 2006 | 10:42 AM
fordninja's Avatar
I have a single 16" fan that I am going to be using. It is a universal fan. Where can I get a controller that also kicks the fan on when the A/C is turned on? Also, is there any suggestions on where to run the wires to to get power to it? Thanks for the help!!
