To anti-seize or not...?
Old Mar 17, 2006 | 10:30 AM
Sarge97's Avatar
I will be changing my plugs out very shortly and I was set on placing anti-seize on the threads. I was told this was common practice. Then yesterday, I heard from someone on the forums here to not place anti-seize on the threads of my plugs. What gives? I have a '97 with a 5.4 and 110,000mi. Do I anti-seize or not...?
Old Mar 17, 2006 | 10:54 AM
JMC's Avatar
JMC
25 Year Member
You will get mixed replies. I use it on mine. But I don't use a torque wrench to tighten the plugs. I go by feel. If you are using a torque wrench and use the OEM spec you will over tighten them and that may damage the threads.
Regards
JMC
Old Mar 17, 2006 | 11:02 AM
MitchF150's Avatar
I have always replaced plugs and torqued "by feel" since I was 12 years old!
Anyway, I didn't use anti-seize or die electic grease when I installed my plugs some 4+ years ago.. Actually, closer to 5 years now...
I've pulled the 'easier' plugs several times since then to check them out, since the Bosch +4's get such bad reviews on here, and they come out very easy and I put them back in 'very easy'.... I usually spray some WD-40 on the threads, just to make it easy to thread, then I use an old spark plug wire to actually thread the plug in, so I KNOW it's not cross threaded and it's seated. Then I just give the socket a nice 'snug' hit by hand and call it good....
90,000 + miles on the plugs and have never had an issue...
Mitch
Old Mar 17, 2006 | 11:04 AM
dmbuie's Avatar
I had mine replaced at 100K on my 2000 5.4. I let the dealership do it because I did not want to wrestle with the rear plugs. My back isn't what it used to be. Since I do not fully trust dealerships, I took out the easiest one that I could get to about a week later and sure enough, it was brand new and there was no anti-sieze compund on the threads.
Old Mar 17, 2006 | 12:08 PM
Zaairman's Avatar
I put anti-seize on my plugs because it was $1 extra for the goo, cheap insurance in my book. But, this is the first vehicle that I have ever used anti seize on. With the spark plugs being so hard to get at, just go ahead and use it. And I have never used a torque wrench before either, I just do it until it's tight. I don't crank down on it though.
Old Mar 17, 2006 | 01:56 PM
BLUE20004X4's Avatar
I put some on mine when I did it. Not gobs of it, just enough to coat it. I've always heard that using anti sieze or similar is necessary when threading into dissimilar metals. Just a thaught. Also, go by feel. Good luck getting a torque wrench in there to do some of the plugs anyways. My dad taught me to use anti sieze on everything and don't reef on things, make them snug.
Old Mar 17, 2006 | 02:02 PM
orvs4me's Avatar
I just replaced mine and I used antisieze on the threads and dielectric grease on the boots.
Like everyone else here I tightened be feel not torque.
Old Mar 17, 2006 | 03:25 PM
chester8420's Avatar
I think the majority of spark plug problems are people overtightning them and crossthreading them.
