White smoke comeing out of exhast pipe
Well yesterday it was nice out so i thought it would be a good day to wash all the salt and whatever eles the winter had put all over my truck, after washing the inside and outside of the truck i decided to wash the engine, i used a very LIGHT spray and made sure to cover and protect any electrical parts before washing. So after about 4hours of drying time with the hood open i decided to start it up when i did i noticed their was somthing wrong right away.
It was shaking in a way it never did before so i went around the truck to look at the exhast pipe and their was hugh amounts of white smoking coming out so i shut it off right away, I'm guessing its a head gasket gone?
it only has 64,000Kilometers on it and its a 5.4L
Oh I also want to point out that when i washed the engine it had been sitting over night for about 13hours or so..
What should I do?
Scott.
What should I do?
Scott.
Well, I let it run for a few min and their was a lot of what looked to be water coming out of the exhast untill i let a few drops hit my hand, i know now that its unbured gas, i'll have to take to a shop on monday i guess, thanks for the help (98Lariet)
Sounds like you got water inside the Spark plug holes. Its very common when someone washes there engine. Thats why you always run the truck right away after washing to burn off any water that got inside or run the engine while washing it.
Your truck is probably fine, but you got to run the hell out of that truck and get it hot to burn the water out of the spark plugs or its going to continue to shake and misfire
96f150 Same Problem
i put up a post for what sounds to me as the same problem white smoke at idle but when you get on it it will turn blueish. i dont have a code so i,am going to do plugs cap rotor and wires last. i did the plugs did not make a difference. i have a strong gas vapor about the whole truck when its running. well if you get to a garage before me let me now how you made out.i will have to be towed to a garage because it is that bad.
(Jwaters) That is exatly the same thing that happens to mine, lots of white smoke rough idle and when you give it some gas it turns blue. Well i spoke to a freind and he is stoping by tommorow with a diagnostic tester, so i'll let you know what we find out.
Well, after takeing all the plugs out cleaning them putting them back in getting a diagnostic test done witch didn't tell me jack ****, i towed it to the dealer and they couldn't find the problem untill they called me today telling me that it was the main computer that all my electronics plug into. Cost:$2100.00 when i pick it up i want to see the old computer for myself...
I'll never in my life wash down my enegine agian!!!!!
WTF? Just doesn't sound right to me man. I don't trust dealerships. And are computers really $2100!!?? OUCH!
Yeah, if it was running properly before you washed it, I'd have to agree with the majority in here.... the water got down in and around the plugs and coils, and it was mis-firing. Let it dry out and it should have smoothed back out.
$2100??? For what??? The ECU?? they're friggin' crazy....
-Joe
-Joe
And this is why I believe washing your engine, no matter how careful you are, is a bad idea. Whether or not your problems are related to this, I dunno. But still.
And $2100 sounds stiff for a repair. I'd find another dealer.
