Torbonator...???
Old Mar 13, 2006 | 11:24 AM
FyrCom's Avatar
If you connect the turbonator to the end of a flammable aerosol can, spray it and light it on fire, it makes a really cool looking fire funnel....
Disclaimer: (read as fast as you can)
Do not try this at home. Should only be performed by experienced professionals in a controlled environment. This practice is in no way an advocation for the misuse of any product forebearing a pyrotechnic effect for a fun thrill and is not endorsed by FyrCom, Inc. FyrCom Incorperated does not endorse this product for its intended use and does not endorse the misuse of this product in any way. Any ideas and/or thoughts on how to use this product are the sole responsibility of the poor fool who owns this product in the first place. Any net profit made during such pyrotechnic showings can and will be taxed by federal and state tax laws. Not recommended with concurrent use of ethyel alcohol or drugs, even though the effect of such pyrotechnic funskies may be enhanced during such exercise. Any other findings of different uses of this product are the sole ideas of others and unless patented, can be used by others. FyrCom Inc. wishes all the best in their endeavors.
Old Mar 13, 2006 | 11:30 AM
I installed one in the tank on my commode. Made it fill up a LOT faster. It worked so well I decided to install on in the commode bowl. Did not work as well, stuff kept getting hung up.
Old Mar 13, 2006 | 11:57 AM
Zaairman's Avatar
Originally Posted by ahaynow1
Does this thing actually work??
Give me cancer now God! Day and night they speak, each word more useless than the one before!
Originally Posted by vader716
I thought we had a member who got maximum benefit by buy 8 (one for each cylinder). Last I heard he was crossing the Arizona desert at mach 1.
Darth, that was me. And I've discovered if you line the intake tube with them, you can break the speed of light
Old Mar 13, 2006 | 12:32 PM
CAkid88's Avatar
It's just a swirler!
Originally Posted by chester8420
I've said this numerous times, It takes 2 for maximum horse power gains!!!! One in the intake, and one to offset it in the exhaust! Why doesn't anyone listen!!
For increased airflow, ya get a K&N in the front, and a flowmaster (or other such airflow increasing exhaust systems), but the turbonator only swirls the air. You doun't need to swirl the exhaust. Besides, they haven't made a turbonator for the exhaust (not that I've seen). Even if they did, I wouldn't be buying one.
Old Mar 13, 2006 | 12:40 PM
FX4_Guy's Avatar
wow...another thread about the turbonator.
Zaairman's Avatar
Pssst....I'll let you in on a secret...everything that we have said in here is a joke! The Turdonator, although is a real product, it a joke. It does nothing. Zip, zero, nada. We joke about it because there are at least 2 "Turbonator" threads started every week, and they always end up with the same results, which are what you are seing above.
Old Mar 13, 2006 | 12:43 PM
FyrCom's Avatar
Just a thought, but...
This should be a sticky?! Might avoid all the new threads if is stays at the top with all the comments...
Old Mar 13, 2006 | 12:46 PM
Zaairman's Avatar
Sticky: Turdonator is a piece of crap!
Old Mar 13, 2006 | 12:50 PM
assasinator's Avatar
wow a turbonator. i need one of these...
so it works by "turbo charging" the incoming air charge.
so how does the charge continue to "swirl" after all of the changes in direction inside the intake, and then through the valve, (which by the way cause their own swirl), and help combustion?
the answer... it doesn't. come on guys.
Old Mar 13, 2006 | 05:22 PM
98Lariet4x4's Avatar
If you have a turbo, and intall a Turbanator upstream from it in the exhaust, could the swirl of the exhaust gasses improve the efficiancy of the turbine?
Thing to make you go hmmmm.....
Old Mar 13, 2006 | 06:24 PM
Bartak1's Avatar
You guys, your all wrong. He asked about the TORBONATOR, not the Turbonator. Sheesh
Torbonator, ahhhhhhh. Thats funny.
You can get one and be like "I will destroy you with my.............TORBONATOR"
Old Mar 13, 2006 | 07:06 PM
temp1's Avatar
Its just a marketing campaign to take advantage of those swirlee yearnings that we get as kids that sometimes extend into adulthood.
Old Mar 14, 2006 | 12:35 PM
CAkid88's Avatar
What about the other side of the globe?
Would it swirl the air the opposite direction if you were on the other side of the equator?
Old Mar 14, 2006 | 12:42 PM
FX4_Guy's Avatar
Everybody knows that if you are south of the equator it swirls air out of your engine!
CAkid88's Avatar
Thumbs up I just noticed!!!
This site actually advertises the Turbonator!!! LMAO
http://www.turbonator.com/index.html?id=adWordsF150
Must be a good thing!
